RV.Net Open Roads Forum: Tech Issues: Starlight 1000 (motion light)
 > Starlight 1000 (motion light)
firecapt1
Sonoma County, CA
Posted: 08/20/11 10:30pm Link  |  Print  |  Notify Moderator
Just a heads-up on the Star Light 1000 Star Light 1000 . I’ve had one for about 3 years and it has worked well. Recently, I had to change the bulb (it burned out), and when I went to unscrew the lens cover to access the bulb, the screw posts disintegrated. The posts are what the lens screws go into in the fixture base. By disintegrated, I mean that the plastic they were made of has degraded to the point that each post just fell apart as I tried to unscrew the lens cover.
My 5th wheel has been parked for the last 2 years (health problems) and the fixture has been in shade the whole time. I keep my 5er hooked up to house power 24/7/365 to maintain the batteries and for occasional use. I can only surmise that the problem is due to heat created by the light coming on and degrading the plastic. Perhaps the plastic that the fixture is made of is not up to the task?
I emailed the company and they offered me free shipping on a new unit (the old one was out of warranty). No explanation or reason for the plastics’ failure.
Just a warning for those of you that have one installed or are thinking of installing one.
Moved to Tech Issues forum from DIY.
* This post was edited 08/21/11 07:38pm by an administrator/moderator *
Frank, Martha & Ryan
2007 Ford F-250 SD Crew Cab
2006 Cougar 289EFS
Happy Trails to you, until we meet again!
SCVJeff
Santa Clarita, CA.
Posted: 08/21/11 01:17am Link  |  Print  |  Notify Moderator
Seems to me that the only heads up here is that the company stands behind the product. No questions asked..
Jeff - WA6EQU
Bobbo
Wherever I park
Posted: 08/21/11 07:40am Link  |  Print  |  Notify Moderator
Free shipping is standing behind the product? He didn't say they replaced the light for free, just that they would SHIP it for free.
I am interested in this because I installed one of these lights about 2 years ago.
Bobbo, Linda and the furry kids (1&1/2 German Shepherds)
2007 Winnebago Outlook WF331C on a Ford E450 Super Duty Chassis
2010 Subaru Forester w/BlueOx baseplate & Ready Brute Elite towbar
welove2drive
Southwestern Illinois
Posted: 08/21/11 08:05am Link  |  Print  |  Notify Moderator
X2
Dave and Marcia
02 Ford F350SD 4X4 SRW Longbed, 7.3PSD Auto
07 Flagstaff 829RGSS
ryanallie1
Magalia, Calif
Posted: 08/21/11 09:24am Link  |  Print  |  Notify Moderator
Hi All.
We have the Star Light 1000 on each side of our Motorhome, for a couple of years now. No problems what so ever. We did how ever put LED Lights in ours. Mostly becasue of the past issues with outside lights with regular RV Bulbs in them, and Melting the Lenses. Live and learn. For what they cost, going with LED Lights is the only way to go. Plus it helps to save Batterty Power to. Good Luck. Happy Travels. dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
firecapt1
Sonoma County, CA
Posted: 08/21/11 09:36am Link  |  Print  |  Notify Moderator
Just a follow-up. I was NOT offered a new unit, just free shipping if I purchased a new one.
I have changed most of my lights to LED's and will be doing so with the new Starlight. As I said in the original post, I believe the problem may have been caused by the heat generated by the conventional bulb. That being said, the fixture still shouldn't degrade to that extent and should have been designed to take the heat.
skipnchar
Topeka or somewhere else
Posted: 08/21/11 10:22am Link  |  Print  |  Notify Moderator
Absolutely it is standing behind an "out of warranty" product. Most companies would direct you to a place you can order parts.
SCVJeff
Santa Clarita, CA.
Posted: 08/21/11 11:29am Link  |  Print  |  Notify Moderator
OK, I missed that part ( and to the rest of you: Razzberry...).
If it were me I think i'd call and plead the case again, maybe ask to see if there is a loop stock replacement since the electronics have changed since. Will they sell you a case only? Swapping the electronics isnt that difficult.
Their position might be that the light was left on for extended lengths and cooked the case as it would do to even the cheap ones (which we've all seen). I have very close to S/N 1 installed on the coach and it is as solid as the day it was installed, only in the last year has it had an LED in it.
Alpenliter
Fulltimer: Wherever we are!
Posted: 08/21/11 12:34pm Link  |  Print  |  Notify Moderator
Looking at their website, I see they now include an LED bulb in it, so apparently they found out that the incandescent bulb was causing problems
My first Wife Linda, 45+years
2004 F-450 CC, DRW 6.0 Classy Chassis Upgrade
Bulletproof Diesel upgrades
1997 33' Alpenlite
400 Watts Solar
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Vietnam Vet '67-'68
Extreme Makeover RV Style!
welove2drive
Posted: 08/21/11 03:34pm Link  |  Print  |  Notify Moderator
Must be why they are standing behind their product as someone suggested. Wayyyyyy behind!
