From my own experience with the controller you have....I had one too...It is not adjustable and will not charge your batteries to the proper voltage...You might want to consider another unit....
05 Dodge 3500 Q-Cab,GearVendor 8 Sp,PacBrake,Banks intercooler & intake,TST R49,Transferflow 70 tank,TrailerSaver Hitch,05 Raptor 3612,Second AC, solar 6 battery sys Xantrex 3000, WEB SITE
http://home.earthlink.net/~wbrown02/wildbillwashere22/index.html
Golden_HVAC wrote: Check the battery water level.
Fred.
X2
Remember "Without Trucker's America Stops" "Buy American Made Only!" It's too late to save your shoes..roll up your pant legs "When all else fails..Amateur Radio" I need more Coffee & Old Bushmills If We Can't Haul It..You Don't Need It. Motor-T Semper Fi
wild bill wrote: The best thing that you could do is to check out the "Handy Bob" advise shown in an earlier post.....You need to know if your install is correctly done and with the right charge controller settings and wire size.....I know this because I changed my setup to Handy Bob's specs over two years ago.... and now my system works as Bob advertises and is trouble free....Only run my gen set when I want the AC on..... visit my web site to see my install.....Hope this is of some help
X2, make sure you can charge your batteries to 14.8, temperature compensated.
