RV.Net Open Roads Forum: Truck Campers: Northern lite modifications
 > Northern lite modifications
fishmanmike
Bend, Oregon, USA
Posted: 08/23/11 03:55pm Link  |  Print  |  Notify Moderator
I have done a few more modifications to my camper and thought I would post them up.
The first one was adding a storage compartment under the rear exterior storage . I keep all my leveling blocks in this. It is just an ammo box from the surplus store.
The next mod I made was to add a hatch to better access the basement storage area. It is a Tempress marine hatch and was very easy to install. I cut the hole right in front of one of the floor supports and then added a floor support on the forward edge of the hole just to be safe.
Floor support
I also added two peices of aluminum angle to the exterior fiberglass that is just behind the wheel wells. I occasionally bump this area while loading and am tired of repairing the gel coat. I adhered the metal with silicone sealant.
Thanks for looking!
2007 GMC crewcab, 3/4 ton, Duramax. 2004 northern lite 10-2000. Bend,Oregon
jamminalong
Pacific Northwest, Wa.
Posted: 08/23/11 04:07pm Link  |  Print  |  Notify Moderator
Greats mods! Not so sure I like the toe-stubber but maybe a throw carpet over the top will help. Really like the idea of storage for the levelers. Thanks for the ideas!
98 Lance Squire
00 Chevy 2500HD 4x4
fishmanmike
Bend, Oregon, USA
Posted: 08/23/11 04:16pm Link  |  Print  |  Notify Moderator
I actually do have a carpet runner over it. It is low profile and I positioned it in front of the fridge so that I would'nt be half standing on it while cooking.
GaryT
Eagle River Alaska
Posted: 08/23/11 09:50pm Link  |  Print  |  Notify Moderator
Thank you for the ideas! Wanted to make little more use of my basement.
2005 F350SD 6.0L w/2004 Northern Lite 10'2 CD
DonCurley
La Sal, Utah
Posted: 08/23/11 11:07pm Link  |  Print  |  Notify Moderator
I really like the concept of the basement access hatch, but if possible, I would prefer something flush with the floor if that was possible to do.
-'07 Dodge 3500/QC/SB/SRW/4x4/6.7L CTD/6-spd auto/35" Toyo MT's/Ride-Rite air bags/RS9000XL shocks
-'07 Apex 8 fully optioned w/220W solar/2 T-145's/2KW Prosine/Honda EU2000i/Tundra fridge/AC/etc
-'00 Jeep Wrangler TJ 4x4, highly modified w/5.9L Magnum V8
sabconsulting
High Wycombe, UK
Posted: 08/24/11 12:15am Link  |  Print  |  Notify Moderator
Great idea - makes all that storage space more usable.
I guess if you did find the hatch being slightly raised was annoying, you could always replace it with a flush one at a later date, maybe just built out of plywood with a flush mounted brass handle.
Steve.
'07 Ford Ranger XLT Supercab diesel + '91 Shadow Cruiser - Sky Cruiser 1
'92 Suzuki Samurai 4x4 1.6
'09 Fiat Panda 1.2
'10 Citroen DS3 1.6 turbo
SoCalDesertRider
SanDiego, CA, USA
Posted: 08/24/11 03:07am Link  |  Print  |  Notify Moderator
I would definitely want a flush hatch. Other than that, the mods are good.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
shanty66
mastic n.y.
Posted: 08/24/11 06:42am Link  |  Print  |  Notify Moderator
Mike, nice and clean. I have a quicky question, what brand mud flaps are on the truck? I just bought a 2011 Silverado and starting to set her up and I can see that I need wide flaps to protect body. Thanks---LOUIE
wnjj
Cornelius, Oregon
Posted: 08/24/11 10:49am Link  |  Print  |  Notify Moderator
If the lid of that hatch is close to flat you could always make the hole oversized and mount it into a subframe so the top ends up flush. I think it would be easier to use the cut-out piece of floor as the door though. Carpet over the whole floor would make it disappear too.
DonCurley
La Sal, Utah
Posted: 08/24/11 11:14am Link  |  Print  |  Notify Moderator
I agree ... I think that would work out best.
