boss302
munster
We bought a 2003 Pace Arrow about a year ago. We just recently turned on and used the refrigerator. I put a therometer in it to make sure that it is reaching the correct temperature. We made sure that the RV was level because I understand that affects the refrigerator. Since we are new to RVing, I am wondering about the following problems. When the refrigerator is closed for several hours it reaches the correct temperature. The minute I open the door of course the temperature drops but it takes many hours before it reaches the correct temperature again. Is this normal? I am afraid to put food in there is it is going to take 5 or 6 hrs to get back to the correct temperature. Would putting in a small refrigerator fan help to get it back to the correct temperature quicker? There was nothing in the refrigerator at the time so over packing would not be a factor. Thanks
downtheroad
Pacific Northwest
If it is reaching the "correct temperature," then it is working and working normally.
All refrigerators (RV or home type) dump a lot of their temp when you open the door. The warmer the ambient temp is the more this becomes a factor. All refrigerators take time to recover this dumped cold air.
A frig fan supposedly helps some.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
SpinRite
Research Triangle, NC
Sounds typical of an empty refrigerator.
Once the reefer is filled with cold food, it will recover quickly.
1. There will be a much smaller volume of newly-admitted air to cool, and
2. all that cold food acts as a large thermal mass, rapidly sucking the heat out of the warm air.
'94 Holiday Rambler Navigator
38', Cummins 8.3 300hp, Allison 3060
pushed by a 2005 Honda Element
workhardplayharder
Treasure Coast Florida
A full frig will hold temperature better than an empty. I like to pre-cool/freeze items before we hit the road.
Trailer Trash 2
Santa Fe Springs, CA
I have two of those frig fans for mine and it maintains the 39 deg I like. I like them because a RV frig does not circulate anything because it dont come with a fan, the cold air just sits there, a fan is a must as far as I'm concerned.
All I have to do now is get the DW to close the door asap, she thinks it like the one at home, open the door and look for something while the cold air goes out and on the floor.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
2009, Dodge, 3500, Q Cab, Cum/Diesel, D.R.W.
Pulling a Super Fine Montana 2980RL
crasster
Dallas
The one thing I'll never understand is why so many RV fridges are way worse in quality and cooling strength than a regular home fridge.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
03FatBoy
Crossville, Tn.
Get one of these:Frig Fan.
Best thing I ever bought for the MH.
Melissa & Steve (MNC USNR retired)
FMCA F335327, GS
'05 HR Ambassador 36PDD, Saturn Vue Toad
8.3L Cummins w/ 6sp Allison
Executive
crasster wrote: The one thing I'll never understand is why so many RV fridges are way worse in quality and cooling strength than a regular home fridge.
Cuz they're different animals completely. You can get milk out of a cow but not out of a horse....  .....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
bfast54
Traverse City ,Mi.
Because they are NOT EVEN close to the same animal, a home fridge uses a compresser and freon, a rv fridge uses Ammonia ....and Heat.
Like comparing a Snake, and a elephant............... because "they both eat"
2000 Ford SuperDuty F-350 Powerstroke,Dually..The Tow Monster
2000 Cardinal 27RK LX
Prodigy Brake Controller
Honda EU3000is Generator
Raytek IR temp,Garmin 1300 /GPS
Doran Pressure Pro
VU Qube Satelite
Rally's attended so far-16
My Blog
Good Sam Member
bowlturner
ny
Hay Executive, what do you think a colt drinks from it's mama , water ???? Not a farmer ??
