RV.Net Open Roads Forum: Toy Haulers: Fuel cell pump problems
Search only in Toy Haulers
 > Fuel cell pump problems
geshields
Humble, TX
Posted: 08/28/11 04:09pm Link  |  Print  |  Notify Moderator
Last night we were camping and went out with our fuel cell 3/4 full and generator 1/3 full. Figured we would transfer fuel from fuel cell to generator tank before bed. I went to do this, turned the switch on and nothing happened. Light came on that it had power but nothing happened. Checked wiring and fuses and everything looked good. Anyway, we disconnecetd and ran to the gas station for 10 gallons of gas..enough to get us through the night.
Just now after we unpacked from our trip, I went to have another look. I loosened the 4 bolts that hold the "impeller assembly" onto the motor. I wanted to see if I could disconnect one from the other to see if it was a locked impeller or dead motor. Just for grins, with the bolts lightly loosened, I flipped the power on. And it started to work. It was pumping fuel. I tightened the bolts back down and it would not start. Loosened them again and it would pump fuel but as soon as I started to tighten them, the pump would stop again.
Am I maybe missing a gasket or something that would give the assembly more room and not be too tight as to lock up. I saw an o-ring in the top cap but did not take the whole thing apart?
Any ideas?
2011 Ford F250 Lariat 6.7L
- Firestone AirBags
- Firestone Wireless Controller
- Superglide 18K
2011 Raptor 365LEV
tom cav
orange co
Posted: 08/28/11 04:14pm Link  |  Print  |  Notify Moderator
the gears swell, take some fine grit sandpaper ,on a flat surface do a figure 8 w/the gear ,you want to take about 004- 008 off one side ,install ,it should work
2007.5 cc,sb.ltz 4x4 d/a ,o9 eclipse stellar 34 lksg 2012 xp-4, 08 4seat rhino . yamaha 125 grizzly 125 breeze
geshields
Humble, TX
Posted: 08/28/11 06:59pm Link  |  Print  |  Notify Moderator
I will give it a shot. Thanks!!
jetboater454
Camping or home
Posted: 08/29/11 05:55am Link  |  Print  |  Notify Moderator
So the impeller is not 100% fuel proof? Need to keep the fix in mind in case mine quits.I guess the impeller is always sitting in fuel.I have filled my stuff,turned of the pump and finish draining the hose,maybe I've been lucky so far.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
tom cav
orange co
Posted: 08/29/11 08:02am Link  |  Print  |  Notify Moderator
nope ,it will swell ,a good proactive solution would be the green stabil ,better for the blended fuels
