RV.Net Open Roads Forum: Travel Trailers: Lighting Oven for First Time
 > Lighting Oven for First Time
jhocksrule
Topeka
Posted: 08/31/11 06:17am Link  |  Print  |  Notify Moderator
I have a new camper. Tried to light the oven on our first trip with the new TT. Does it take a while to get it lit the first time???
JJBIRISH
Butler, PA, USA
Posted: 08/31/11 06:25am Link  |  Print  |  Notify Moderator
The air needs to be purged from the lines… light the stove burners first to know the gas is that far, then light the oven…
Love my mass produced, entry level, built by Lazy American Workers, Hornet
donn0128
Pronounced Ore-gun
Posted: 08/31/11 06:40am Link  |  Print  |  Notify Moderator
Yes, it takes a long time. I use a gas match. Be sure to press the oven control knob in and hold it while lighting the pilot. Move the gas match around a bit and be sure to heat the thermocouple too. When this gets hot enough gas will flow and the pilot will remain lit.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
2oldman
Soap Lake WA
Posted: 08/31/11 06:59am Link  |  Print  |  Notify Moderator
Not if you turn the oven temp control to something like 300*, then light it!!
past-MIdirector
Michigan
Posted: 08/31/11 07:13am Link  |  Print  |  Notify Moderator
X2 on turn control to 300.
downtheroad
Pacific Northwest
Posted: 08/31/11 07:29am Link  |  Print  |  Notify Moderator
I use one of these...It doesn't really take all that long to get it lit.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
jhocksrule
Topeka
Posted: 08/31/11 07:34am Link  |  Print  |  Notify Moderator
I was able to get the burners on the stove to light, so I know gas is getting there. So are you saying instead of pushing in the knob and holding it on the pilot postion, I should turn the knob to 300 and then light the pilot???
2oldman
Soap Lake WA
Posted: 08/31/11 07:41am Link  |  Print  |  Notify Moderator
Works for me. The entire oven gas bar will light, not just the pilot. However, on my oven there's nothing to hold in the pilot position.
BB_TX
McKinney, Texas
Posted: 08/31/11 07:53am Link  |  Print  |  Notify Moderator
Like the above, I purge the lines by lighting the burners first. Then turn them off.
Then using the propane match, I hold it under the pilot while turning the knob to pilot and pressing in on the knob. After a few seconds with the propane match still in position (and without releasing the knob), I turn the knob to about 200 or so and the main burner lights. Lights much easier than just trying to light the pilot by itself. Then I can turn the burner off if I only want the pilot on.
jhocksrule
Topeka
Posted: 08/31/11 09:44am Link  |  Print  |  Notify Moderator
I will definately give that a try. See if that works for me. Thanks for all of the help.
