RV.Net Open Roads Forum: Thermostat Conversion - Analog to Digital - Resolved
 > Thermostat Conversion - Analog to Digital - Resolved
Bill/Diana
Southeastern Pennsylvania
Posted: 09/05/11 09:51am Link  |  Print  |  Notify Moderator
For some time now I have read about many of you that made the AC and furnace thermostat coversion using the Hunter 42995 thermostat. Last week while in Walmart I purchased the Hunter and now in the process of the conversion using these directions. Click here for directions.
All is going well except my old thermostat also has an RH wire that is not shown in the conversion directions. Should I connect the RH wire and if so do I still leave the jumper in place between RC and RH? Also, do I need to change the switch setting on the back of the thermostat?
Thanks in advance for the help.
Bill
* This post was edited 09/06/11 09:11am by Bill/Diana *
Bill & Diana
Please click here to visit our Website
Chris Bryant
Arden, North Carolina
Posted: 09/05/11 09:58am Link  |  Print  |  Notify Moderator
It depends on which Air Conditioner you are working with.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
downtheroad
Pacific Northwest
Posted: 09/05/11 10:01am Link  |  Print  |  Notify Moderator
Can't remember how exactly I did mine ( Heck, I can't even remember what I had for breakfast).
I know I did leave the RH jumped on the digital stat and I think I just tested it by both ways with the existing RH until it worked correctly. You can't hurt anything by testing it both ways.
I do remember that I didn't use the existing Red; I just caped it.
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
Chris Bryant
Posted: 09/05/11 10:32am Link  |  Print  |  Notify Moderator
Thinking about it- I think both DuoTherm and Colman would have RH and RC jumpered, but on DuoTherms they are hooked to ground, on Coleman, they are hooked to +12.
Bill/Diana
Posted: 09/05/11 12:31pm Link  |  Print  |  Notify Moderator
Thanks for the replies folks.
The air conditioner is a duo therm. Will that determine how the RC & RH wires are connected?
Bill/Diana
Posted: 09/06/11 09:15am Link  |  Print  |  Notify Moderator
This morning connected all the wires including both the RC & RH. Left the jumper in place on the thermostat terminal strip between the RC & RH posts. Also, left the selector switch on the back of the thermostat in the HG position.
Both the AC and the Furnace seem to be working just fine with the new Hunter 42995 Thermostat. Thanks for the help and a special thanks to the fella who so thoroughly documented the procedure fo making the conversion. Now I'm anxious to take our next trip and see how well it really works.
Thanks again.
Bill
Chris Bryant
Posted: 09/05/11 02:53pm Link  |  Print  |  Notify Moderator
They should be jumpered, hooked to ground.
Bill/Diana
Posted: 09/05/11 03:00pm Link  |  Print  |  Notify Moderator
Chris....
Thanks for the reply. Tomorrow I will finish the wiring and connect the RH and RC wires to their respective location on the Hunter terminal strip. I'll leave the jumper in place. Then I'll try running the AC and then try running the furnace to verify all is working properly. The Hunter factory directions explain the selector switch on the back is for the heat funtion. HG for gas and HE for electric. So I'll leave the switch in the HG position.
I'll report back on this thread after running the test tomorrow.
