RV.Net Open Roads Forum: Towing: Where can I weigh my trailer?
Search only in Towing
Open Roads Forum  >  Towing
 > Where can I weigh my trailer?
jeff0219
Georgia
Posted: 09/05/11 08:39pm Link  |  Print  |  Notify Moderator
Where can I weigh my trailer? I need the tongue weight and the gross weight of the overall trailer. Anyone know if you can use the highway weigh stations to get a weight? When I am on a trip I pass these all the time. Just going to a scale in-between trips may not get me a good enough weight. Probably get me in the park but that may not be close enough.
donn0128
Pronounced Ore-gun
Posted: 09/05/11 08:54pm Link  |  Print  |  Notify Moderator
I use the DOT weigh stations all the time. As long as they are closed the scales are generally still on, so you can go and spend as much time as you want getting weights.
Don,Lorri,and Charlie Bear 2016
The Other Dallas
4*phun*2
Canada
Posted: 09/05/11 09:08pm Link  |  Print  |  Notify Moderator
Almost any big truck service centre will have a set of scales. Drive on, holler private truck into the microphone. Go in and pay.
Glenn & Karen
'08 Chevy LT 3500 HD 4x4 CC LB DRW (nice hips)
'06 F350 4X4 Lariat CC LB DRW (nice hips) retired
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
brirene
midwest
I usually go to a CAT scale at a local truck stop on the way home. Cost is 7 or 9 bucks, but you can get a second weighing for another dollar.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
wmoses
Houston, Texas, USA
Posted: 09/05/11 09:37pm Link  |  Print  |  Notify Moderator
Have no clue where in GA you are but there may be a Flying J near you. Check out this link.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
LewMichele&Paws
At a gas station in Cowlitz County WA
Posted: 09/05/11 10:13pm Link  |  Print  |  Notify Moderator
Our local dump (waste management to be pc) has a scale I've used to weigh our truck.
'06 Ford F350 V10 CC 4X4 SB auto 4.10
'06 Arctic Fox 811
Don't lose your head...to save a minute...you need your head...your brains are in it...Burma Shave
States visited in our RV...
#40Fan
Colorado
Posted: 09/05/11 10:54pm Link  |  Print  |  Notify Moderator
Cat Scales
2013 Arctic Fox 22GQ
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
JIMNLIN
Oklahoma
Posted: 09/06/11 08:34am Link  |  Print  |  Notify Moderator
My small town feed store/ag dealer has a feed mill with platform scales open 24/7. I weigh the trucks front and rear axle seperatly first. Then hook the trailer and repeat each axle on the truck/then truck and trailer/then just trailer while its still hooked.
That will give mw my trucks loaded front and rear axle weights/pin weight/trailer gross axle weight.
Some places where you can weigh your RV:
RVSEF Weight & Tire Safety Program a service offered at many RV rallies and shows
CAT Scales
Weber Son & Service Repair Inc.
Truck stops
Farm co-ops or feed mills
Some sand and gravel yards
Dave H M
IL
Posted: 09/06/11 09:46am Link  |  Print  |  Notify Moderator
I know the folks at the local grain elevator and have free access there.
SoCalDesertRider
Arizona desert
Posted: 09/06/11 09:47am Link  |  Print  |  Notify Moderator
I have used scales at-
-The local dump. I go there on a day when they're not busy, drive on the scale, explain I don't have anything to dump, read the scale for each axle and drive off. This is good for getting truck gross weight and truck and trailer separate axle weights. They don't mind, since it is a quick process that doesn't tie up their scale.
Unhooking the trailer to get a tongue weight would likely piss them off. Coming back later with the truck without the trailer and getting the gross weight of the truck, then comparing to the previous gross weight of the truck with the trailer hooked up, an easy subtraction is made to reveal the tongue weight. [emoticon]
-the local moving van company. This is a pay to use scale. They don't mind fenagling around with unhooking a trailer, so long as there is not a line of trucks waiting to use it. There is never a line of trucks waiting. They charge $10 and provide a certified receipt.
-the local rock quarry. Same as above, so long as there is not a line of trucks waiting.
-the local metal recycler. Similar to the local dump. Always ask permission first.
-commercial truck stop. Same drill as the moving company.
-I stay off the DOT highway scales in CA. They do not want any pickups on their scales and will yell at you if you use them.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
