RV.Net Open Roads Forum: Opps, pulled camper jack from camper a bit.
 > Opps, pulled camper jack from camper a bit.
Wanderin fool
Woodland Park, Colo.
Posted: 09/05/11 08:51pm Link  |  Print  |  Notify Moderator
Hello gang! I slightly pushed the right rear Atwood mount inward a bit when I made contact with my trailer. I didnt post a pic as it wouldnt do much. I have a slight wrinkle on the back, and the mount shifted enough I can see the jack is a bit inward from the side and back. Im planning on taking it off and using longer screws? I think it will re align okay, but would like advice on this. Its rather minor, but enough to have moved the mount. Thanks, Frank.
Duramax/Lance 835
KTM/Arctic Cats
Motorized advocate in Colo. CMTRA, our local club.
www.cmtrail.org come visit!
Other Forums:
Thedieselplace.com ( chevsforever)
KTMtalk.com (xrcrasher)
Pontoonboating.com (Lounge Lizard)
Arcticchat.com (400crasher)
silversand
Montreal
Posted: 09/06/11 05:28am Link  |  Print  |  Notify Moderator
I would verify if:
a) the jack itself is/isn't bent;
b) if the above is negative, the threaded material your jack screws penetrate haven't been completely/partially stripped.
...then, others here who have had this happen will probably chime-in for an effective repair...
Good luck,
Silver-
Silver
bobndot
NY
Posted: 09/06/11 06:32am Link  |  Print  |  Notify Moderator
However you fix it , make sure the fix is solid . Caulk the jack plate as well as the lag screws . hopefully that will prevent something like this :
http://truckcampernews.rvtravel.com/2009........otos-tell-story-truck-camper-damage.html
http://www.rv.net/forum/index.cfm/fuseac........d/tid/20089427/srt/pa/pging/1/page/2.cfm
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24120109/print/true.cfm
sleepy
Oak Ridge,Tennessee
Posted: 09/06/11 06:36am Link  |  Print  |  Notify Moderator
Don't approach this as slight damage.... it is always a big deal.
It holds a share off the weight of your camper up, down, and stored.
Any miss-fit when repairing will soon allow water infiltration... big time damage.
Any alignment promlems will make this jack push againest the other 3 jacks (sideways) putting a strain on their connections to the camper... which may make them leak around their caulk... and also affects the stability of the camper, especially when high in the air.
Check the (filon) siding for hairline cracks... they will let water in
To repair mine when it was nudged by a wrecker driver when my camper was parked... the whole back of the camper had to be removed and replaced... the filon was broke, and a new jack because it was bent ever so slightly... it made the camper "walk" when extended. (their insurance paid, the work was done at Lance... Lancaster, CA.)
Good luck
Sleepy
2003 Lance 1161,/slideout/AGM batteries/255W Solar/propane generator/Sat dish/2 Fantastic Fans/AC/winter pkg
AirFoil, Trimetric, LED lights, Platcat vent heat
2003GMC K3500 LT/Crewcab/duramax diesel/allison/dually/4x4/OnStar/front reciever mounted spare
SoCalDesertRider
SanDiego, CA, USA
Posted: 09/06/11 08:28am Link  |  Print  |  Notify Moderator
Usually the brackets that hold the jack to the camper are what bend, though sometimes the jacks themselves will bend too. You can take the brackets off the camper and off the jack, put them in a vice and straighten with a large crescent wrench and a pipe. The jack can be straightened in a shop press.
As far as damage to the camper itself, that's a whole 'nother story. Mine were wood framed and aluminum sided. Drilling new holes in the jack brackets and using new screws in new holes in the wood is a good fix, as is using larger screws in the existing wood holes. Then caulk everywhere.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
Wanderin fool
Posted: 09/06/11 08:35am Link  |  Print  |  Notify Moderator
Thanks for the great responses! The jack and mounts are okay, its the mount that pulled away from the camper just a bit. There is about 1/8 to 1/4 inch gap at the top of the mount. Im guessing a Lance is similar to most other campers in that area of construction.
sleepy
Oak Ridge,Tennessee
Posted: 09/09/11 03:27am Link  |  Print  |  Notify Moderator
Wanderin fool wrote:
Thanks Sleepy. You have a lot of good info to give. Being an 01 Im just guessing its wood,,,
dit: opps, you said not to guess, my bad!
That guess is pretty safe about the frame material... seeing that it's an 2001 model... after 2004 this question could be iffy depending on model.
I'm admittedly parinoid about repairing any camper with filon skins... water infiltration is a camper killer... as we occassionally see posted here on the forum.
Best of luck on your repair.
Remember... use no silicone caulking products... its in your Lance Manual
Best of Luck to You.
Sleepy
Wanderin fool
Posted: 09/08/11 07:54pm Link  |  Print  |  Notify Moderator
sleepy
Oak Ridge,Tennessee
Posted: 09/06/11 09:02am Link  |  Print  |  Notify Moderator
is yours aluminum or wood framed
Don't guess...
make a phone call to Lance with your serial number... its free
they can tell you what is behind your filon siding... even furnish you with a schematic... by email... also free
