horatio54
Pa
anybody have any unique ways to mount tv outdoors
TMBLSN
Washington State
I use a mount called LevelMount. You just attach a small bracket to the wall, most of the mount is attached to the TV. I have multiple mounts so that I can move the TV around. I even bolted one to the outside wall of the trailer. Makes for great tailgating.
2001 Bigfoot 24DB (Class C)
2006-2011: 2006 Jayco 275BHS (5th wheel)
2002-2006: 2003 Northern Lite Ten-2000CD (truck camper)
2002-2011: 1998 Chevrolet C2500HD for hauling camper and towing 5er
Lee
nesbitram
Mississippi
This is the one I bought a couple of weeks ago. wall mount It comes with 2 mounting brackets, but this one only works for TV's that are 27" or less because of the holes in the back of the TV are wider on larger TVs.
2006 Dodge Ram 2500 CTD
2012 Rockwood 8281SS (May 2011)
PSU_RVr
PA
Love the profile pic of your rig. That's me up and towards the left.
I'm currently trying to come up with something to mount in one of the basement compartments. I do have a thin wood wall that I can pretty much mount anything to. But don't think it would work for you.
Newmar Canyon Star 3920 Toy Hauler
Where it's been, the crew -Bandit, Morgan, Sherman. It:
jmanatee
Alstead, NH
I did ours this way http://www.outerland.com/rv/P_n_OutsideTV.cfm?whatarea=PNR
Jon
RV Web Site | 50 Night Cross Country Trip
Our Solar Install | Roof Replacement Project
Twenty years from now you'll be more disappointed by the things you
didn't do than by things you did. Explore, Dream, Discover. Mark Twain
2008 Monaco Cayman XL 38PBD
PSU_RVr
PA
That looks great. Did something similar on my previous trailer. (not nearly so nice looking)
I need to learn to weld.
Entropy69
Ohio
nesbitram wrote: This is the one I bought a couple of weeks ago. wall mount It comes with 2 mounting brackets, but this one only works for TV's that are 27" or less because of the holes in the back of the TV are wider on larger TVs.
Can that one lock in place? I'd like a mount like this, but I don't want the TV moving around or popping out of the mount if I hit a bump while driving.
2007 Four Winds 5000 28A
Chevy Workhorse Chassis, 6.0L Vortec
RoyB
King George, VA
I havent done one but I kinda like the idea of having it recessed inside the pass-through storage area. Then it would not get rained on. Also you could just close the storge bay door when you had to walk away for a few minutes...
You should be able to rig up one of the many wall mounting LCD brackets you see at Walmart. the LCD TV isnt going to weigh very much...
Just my thoughts
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
nesbitram
Mississippi
Entropy69 wrote: nesbitram wrote: This is the one I bought a couple of weeks ago. wall mount It comes with 2 mounting brackets, but this one only works for TV's that are 27" or less because of the holes in the back of the TV are wider on larger TVs.
it does have a set screw that locks it into the mount and knobs to keep the arm from moving. I installed one of the mounts on the outside for tailgating, but have not installed the other one. I just put the TV flat on the bed when travelling. Depending on what it is screwed into on the inside I would be a little worried about the bouncing.
Jrmay
Missouri
Take a look at the mounts Monoprice.com sells. I bought and installed a swivel mount in my cargo bay for right around $30. Swings out when we want to watch it, and folds flat to the back wall when were done.
