RV.Net Open Roads Forum: Fifth-Wheels: Lippert frame ID
 > Lippert frame ID
pigbike
Posted: 09/06/11 07:24pm Link  |  Print  |  Notify Moderator
How does one identify if a used 5th wheel has a Lippert frame. Is there a easy way to tell?
C Schomer
Buckeye, Az.
Posted: 09/06/11 07:46pm Link  |  Print  |  Notify Moderator
My 5ers have all had a tag near or on the side of the hitch with the mfgr name and serial # of the frame. Craig
Luke Porter
Not on the road :(
Posted: 09/06/11 08:09pm Link  |  Print  |  Notify Moderator
Do you mean the pin box? That is who manufacturered the pin box--not the frame.
I don't think there is an easy way to tell who built the frame. Probably have to now what frame the RV manufacturer used.
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
sirdrakejr
Las Vegas, Nevada
Posted: 09/06/11 08:50pm Link  |  Print  |  Notify Moderator
On all the 5ths I had, the manufacturer of the frame also made and attached the pin box.
Frank
overthehillbill
Patterson, Ca.
Posted: 09/06/11 08:58pm Link  |  Print  |  Notify Moderator
Frank
I had a lippert frame with a Atwood pin box.
Bill
'08 Cedar Creek 32TK, 35'9", 13,990#
'01 F-250,Lariat, 7.3L, SC, Auto, LB, JW Towmaster Tranny, 6.0L Tranny cooler, DP custom tunes, 4" Turbo back exhaust, Auto Meter Gauges, Firestone Air Bags. '07 Headlights and Grille, Prodigy P-3.
kennethwooster
Perryton Tx USA
Posted: 09/06/11 09:01pm Link  |  Print  |  Notify Moderator
I had a lippert frame with Mor Ride pin box. Ck and see what the manufacture uses. About the only sure way. however Lippert does make a pin box too that goes with their frame.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F250 2011 model, 4X4, King Ranch.
18K SuperGlide Hitch
SoCalDesertRider
SanDiego, CA, USA
Posted: 09/07/11 12:02am Link  |  Print  |  Notify Moderator
Lay under the trailer and look around for the nasty, incomplete frame 'welds'. Shouldn't take long to find them...
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
Chris
Shelter Bay, Wa
Posted: 09/06/11 09:10pm Link  |  Print  |  Notify Moderator
Does it have cracks or broken welds? If so it is most likely Lippert! Chris
My Rig
2001.5 2500 STD CAB AUTO SLT 4x4, CTD 4:10's, Bomb'd to Tow
2005 Cardinal 29WBLX.
laknox
Arizona
Posted: 09/06/11 10:34pm Link  |  Print  |  Notify Moderator
The builder plate should be on the frame =above= the pin box bolts. The pin box should have its own builder plate or stamp, no matter who built it.
Lyle
1936 John Deere Model A
Old-Biscuit
Across the USA
Get the trailer VIN and date of manufacture...call Mfg. and find out who made their frames during that time period.
Some Mfg. have used different frame vendors over time, so what they are using now may not be what they used then.
 > Lippert frame ID
