RV.Net Open Roads Forum: Tow Vehicles: Ecoboost towing heavy (moderate) in Colorado Mountains
Search only in Tow Vehicles
 > Ecoboost towing heavy (moderate) in Colorado Mountains
skipnchar
Topeka or somewhere else
Posted: 09/09/11 03:01pm Link  |  Print  |  Notify Moderator
Returned yesterday afternoon from a couple of weeks in Colorado with the new truck. One of the reasons I wanted to go there was to find out how good it would tow at high altitude and steep grades. I'll give it an A on both tests.
ON the last day, I had stopped overnight at "Timber Creek" NPS campground, on the west side of Rocky Mountain Park, near Grand Lake. It had been raining solidly all night on Monday and all day Tuesday. Still looked like it was going to open up again on Wednesday so I decided to head on for home a day early. Debate about whether to go over Berthoud Pass which would take me out of the mountains through Denver, or go through the park on Trail Ridge Road and come out in Loveland. It was a no brainer for me to go over Trail Ridge because I HATE driving in Denver traffic.
It was only drizzling a little rain as I turned north out of the campground and headed toward Milner pass. It was pretty easy driving up to the pass through the continental divide at Milner but that's only 10,700 feet and it was obviously pretty close to the ceiling there. I would find that the ceiling was quite a bit lower on the east side and was socked in solid all the way to the valley floor.
Within a mile after the pass I drove into the clouds. It was dense enough to make seeing the yellow line on the road difficult to see at times. At least that kept me at the 35 MPH speed limit on that part of the road (for the most part). It also kept traffic down. Fair amount of traffic coming from the East side but never saw another vehicle going from the West as I was.
The truck handled the grades easily in 4th gear, towing approximately 9,000 lb. On those occasions when I DID get up around 40 MPH it even locked up the torque converter in 4th gear and STILL would easily accelerate when I asked it to.
I know that Trail Ridge is not the toughest mountain pass in Colorado but it's no slouch either. Lots of 6% grade with some 7% thrown in and a number of 15 MPH curves scattered throughout the distance.
I had come with great expectations for towing with the Ecoboost but it actually even exceeded (by far) the ease of handling the grades, both up and down. The small 6 cylinder engine doesn't have QUITE as much engine braking as the larger V-8s I'm used to but it certainly was adequate to avoid the need for more than occasional braking on the downward side. I prefer using the select shift to handle grade braking rather than using tow/haul to do it. I've always thought tow/haul gives more help than is needed and still find that to be true with the new transmission but it IS better than it used to be. Still being able to select the gear you want to use WITHOUT it automatically downshifting every time I touch the brake is a better solution.
Under MOST driving conditions you don't every even hear the engine, with only a low pitched purr from the twin turbos but during the climb the turbo sound was more pronounced but still with about the same low pitch. Even at the highest elevations on Trail Ridge, over 12,000 feet high, I noticed no loss of power and 4th gear was all that was needed to climb and that's with around 1500 RPM on the tach.
I can now say that I would be confident to take the truck on any mountain grade I've ever climbed and know it will do the job as well as anything out there. I am AGAIN impressed with what Ford has done with that engine. Not much they can do about the rain I guess so at least they gave me an easy means of driving out of it. Rain was gone by the time I got to FT Morgan.
Over all it was a great trip with good weather. Little did I know that when the heat wave left it would usher in all that rain. that's about as long as I've seen it rain in the Rockies but I'm sure it happens often.
Guess I'll have to go LOOKING for something tougher to see if I can make it at least sweat a little bit [emoticon]
I didn't mention anything about fuel economy in this post because as I've often said before, I don't see much difference in fuel mileage when mountain towing over towing on flat land. Yes It did worse going up but it was balanced by doing better coming down and the net result was only about a .5 to 1 MPG loss in economy. Mileage didn't change much from driving on the previous trip and other than that 1 MPH loss for mountain towing, I still got right at 10 MPG for the towing part of the trip.
* This post was last edited 09/09/11 05:00pm by skipnchar *   View edit history
larry barnhart
wenatchee. wa usa
Posted: 09/09/11 03:15pm Link  |  Print  |  Notify Moderator
Yes just think it is a 3.5 V6. that really is a small engine for that power.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Kevin O.
Connecticut
Posted: 09/09/11 04:28pm Link  |  Print  |  Notify Moderator
Glad to see the Ecoboost is living up to your expectations!!! I leave in 2 weeks for our last trip of the year and cant wait to see how my new Ecoboost tows compared to my old 07' 5.4!!
KEVIN ">
DW-Debbie ">
DS-Tyler 11yrs old">
DD-Makayla 8yrs old">
MERIDEN,CT
2001 Ford Powerstroke F350 Lariat
2012 Keystone Outback 292BH-OLD
2016 Jayco 29.5BHDS-NEW
ib516
Way up north eh
Posted: 09/09/11 05:15pm Link  |  Print  |  Notify Moderator
Nice report Skip. Glad you had a safe trip.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
All above are sold
Current: 07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
fla-gypsy
North Florida
Posted: 09/10/11 06:36am Link  |  Print  |  Notify Moderator
Nice detailed report Skip. Now if they will just make a 5.0 EB for the SuperDuty line I will be all over it
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
tnance
Nixon/Texas
Posted: 09/10/11 06:42am Link  |  Print  |  Notify Moderator
Since it was overcast when you made the trip, here is what it looked like at the top. A beautiful drive.
2005 Freightliner M2 106 class 7 HDT
2004 Teton Sunrise Grand
Jeep Wrangler toad
...PICTURES...
skipnchar
Posted: 09/10/11 07:30am Link  |  Print  |  Notify Moderator
Thanks for the photo. I've driven the road on many occasions during clear weather, rain and snow. This one was the worst visibility I've run into for at least quite a few years. Each pass DOES have it's own beauty but my preference is clear weather so those gorgeous views of the valley floor below can be enjoyed.
Hannibal
Tampa Bay Area
Posted: 09/10/11 07:42am Link  |  Print  |  Notify Moderator
Great report! Glad you had a good safe trip. The Ecoboost sounds like the beginning of a whole new era of tow vehicles.
'10 F250 XLT CC SB 5.4L 5spdTS 3.73 101k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'. Equalizer 4 pt 10k.
MadMav
Colorado Springs, CO
Posted: 09/09/11 05:41pm Link  |  Print  |  Notify Moderator
Turbo's rule up here!
Good report.
Mav
"A fifth wheel trailer is a bi-level towable mobile home."
Larryect
Home
Posted: 09/09/11 05:49pm Link  |  Print  |  Notify Moderator
Sounds pretty amazing. Towing my 25ft Layton fth wheel with an 8300 pound Gvw (haven't weighd it) on something like a 2500 mile round trip from CA through New Mexico and back my F350 6.0 diesel averaged 9.9. Of course I was probabaly driving 65 - 70 as well.
