RV.Net Open Roads Forum: Class A Motorhomes: Deep Cycle Batteries
 > Deep Cycle Batteries
philandmargo
Wichita Falls, TX
Posted: 09/13/11 12:06pm Link  |  Print  |  Notify Moderator
I have a 2000 Tiffin Zephyr. It has a bank of 4 12 volt deep cycle batteries for the coach. The bank also starts the generator. The engine start batteries are in a different bank. Looks like it is getting time to replace batteries. Does anyone have a recommendation? Is anyone using Optima batteries? Do the Optima batteries live up to the hype and worth the extra expense? Thanks
2oldman
Winchester WA
Posted: 09/13/11 12:18pm Link  |  Print  |  Notify Moderator
Optima in heading posts
jauguston
Bellingham, WA
Posted: 09/13/11 12:54pm Link  |  Print  |  Notify Moderator
Optima makes good batteries. They are great for the right application. Motorhome house batteries is NOT a good application. Flooded lead acid 6v golf cart type batteries are by far the most common type used because they do a good job at a reasonable price. If you want to spend the much higher cost of AGM take a look at Fullriver DC-224-6 AGM's.
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
pianotuna
Regina, SK, Canada
Posted: 09/13/11 12:58pm Link  |  Print  |  Notify Moderator
Hi,
If you want a reasonably priced agm battery contact Randy at bestconverters.com
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
trickyvic3
Raymond NH.
Posted: 09/13/11 01:03pm Link  |  Print  |  Notify Moderator
Are you sure they are 12volt and not 6volts ?
cquinn5
Titusville FL US
Posted: 09/13/11 01:33pm Link  |  Print  |  Notify Moderator
Yes they are 12v. I have the same motorhome and installed 4 Deka group 27 AGM batteries 10/16/2002. They are still working great.
Cliff
Cliff & Karen Quinn
The Great Outdoors
skipnchar
Topeka or somewhere else
Posted: 09/13/11 02:34pm Link  |  Print  |  Notify Moderator
Lost of extra expense to get a lot less power.
mena661
Posted: 09/13/11 03:10pm Link  |  Print  |  Notify Moderator
X2, I would replace them with four 6V's from your local Costco or Walmart. They are taller than 12V's so you'll need to check the height clearance. The 6V's are around 11" high.
Trojan L16 6V's 740 Amp-hours
