RV.Net Open Roads Forum: Beginning RVing: Winterize black water tank
 > Winterize black water tank
N1VWD
Vermont
Posted: 09/14/11 06:54am Link  |  Print  |  Notify Moderator
Hello to all in the group.
I live in VT and I am in the process of winterizing my TT for the year. I have read that after draining the black water tank you should always add 3 to 5 gallons of water to the tank to keep any remaining solids from drying out and keep every thing in solution. Do you still do this at the end of the season? What about freezing, wont it damage the tank? If I drain the tank what about any residual nasties left behind wont they dry out.
All replies will be greatly appreciated.
Brad N1VWD
Yesterday is history, tomorrow is a mystery and today is a gift.
M GO BLUE
Southgate, MI
Posted: 09/14/11 07:00am Link  |  Print  |  Notify Moderator
Flush the black tank as best as you can and drain completely...then pour about 1/4 gallon of RV antifreeze into the tank to keep the drain seal moist...then close the toilet and dump in enough the keep the toilet seal covered with RV antifreeze
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
downtheroad
Pacific Northwest
Posted: 09/14/11 07:06am Link  |  Print  |  Notify Moderator
We don't have 'Vermont' winters, but it still does freeze from time to time.
I really give the black tank a good flushing and then add about a gallon of water and about 1/2 gallon of rv anti-freeze. Just enough to cover the bottom of the tank and get up against the valve...
This keeps any left over solids from becoming 'real solid' and protects from freeze damage.
Remember, there is plenty of room in an empty tank for water to expand.
In 4 rigs and many many winters this has worked great.
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
korbe
California
Posted: 09/14/11 07:12am Link  |  Print  |  Notify Moderator
I will drain and flush it out a couple of times - the normal process after a HARD campin' trip. It sits there primarily dry for 6 months. Small amounts of frozen water will not damage a tank. If you are worrying about solid buildup, get rid of it before winterizing, IMHO.
DavidP
Raleigh
Posted: 09/14/11 09:59am Link  |  Print  |  Notify Moderator
skipnchar wrote:
kind of like a pop sickle but won't damage anything. Good luck / Skip
You win the funny line of the day award. [emoticon]
nelson
Clio,Mi USA
Posted: 09/14/11 07:17am Link  |  Print  |  Notify Moderator
I drain mine and keep the valve open all winter or untill I head south.
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
rvten
Crossville,TN
Posted: 09/14/11 07:22am Link  |  Print  |  Notify Moderator
When we lived in WI. I just flushed out the black tank and left it set till spring. Never had a problem.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
skipnchar
Topeka or somewhere else
Posted: 09/14/11 08:08am Link  |  Print  |  Notify Moderator
You are absolutely correct about NEVER allowing a black tank to remain empty. No matter how well you flush the tank it will always have some solids remaining and they can cause odors and clogs if allowed to dry out and turn to stone. I use a mixture of half water and half antifreeze in mine each winter. It turns to a semi solid, kind of like a pop sickle but won't damage anything. wouldn't cost that much more to use all antifreeze. I would think that it wouldn't be necessary to use any more than a couple or three gallons however. Main thing is to keep the floor of the tank flooded.
Good luck / Skip
mojoroo
Midwest
Posted: 09/14/11 10:07am Link  |  Print  |  Notify Moderator
ah yes a poopsickle!!!
2oldman
Orland
Posted: 09/14/11 10:29am Link  |  Print  |  Notify Moderator
Black tank flush winterize
Leave tanks empty?
Water in black after empty?
