dantaut
Campbell CA
Does anyone have any experience towing a 2008 Saturn Vue AWD, dos and don'ts, do you have to pull a fuse, and if so which one?
happy-2
calif
Hi there, I tow a 2008 vue and yes i pull the 2amp fuse from the panel on the pass side ft seat.I also marked the fuse with a black sharpy pen and I use a pair of needelnose plyers.I went through a lot of no starts to find this out .
happy-2
calif
Hay dantaut, if you want call me at 916 216 6364 iIm in rocklin,by sacto
RVGeary
Colorado Springs, CO
Just returned from a 1,000 mile trip towing 2008 Vue for the first time. I have a charge line running from the rv, hence no dead battery. Put transmission in neutral and key to accessory. No problems at all. Geary
chastho
arkansas
I tow a 2006 Vue and have a charge line from MH and do not pull any fuse.
happy-2
calif
where do you run the charge line from?
kjbkjb
Wisconsin
I tow a 2008 Saturn Vue. I installed a rocker switch for the fuse that needs to be pulled. It is much easier than pulling the fuse.
bsinmich
Holland, MI
(II have a charge line for the bgrake system and was wondering about not pulling that fuse. I will try that next time.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
JC2
Mo
This is what we use on our 08 Saturn to avoid having to pull the required fuse everytime. We mounted it just above the fuse panel on the passenger side.
http://www.rv-partsplus.com/home/accessories/
2004 Newmar DSDP 4015,370hp Cummins ISL,Spartan MM Chassis,2008 Saturn Vue,FMCA #402879,NKK 19776
Hjudge49
St. Augustine, Fl.
Easier and cheaper way to avoid pulling the fuse is to buy a push-pull circuit breaker, wire it to a replacement fuse, after "blowing" the replacement fuse by shorting it out. I soldered 14gauge wires to the top of the fuse (chip away just enough plastic to nmake the connection, touch one wire to each terminal of a battery to blow the fuse, then connect to the circuit breaker. Mount the breaker in an inconspicuous location and replace the fuse. Now you can disconnect without opening the panel. On my 2006 Vue, it also made a great anti-theft device.
