RV.Net Open Roads Forum: Tech Issues: Question about Batteries
 > Question about Batteries
mram10
Everywhere
Posted: 09/15/11 07:25pm Link  |  Print  |  Notify Moderator
Since we talked last I installed a 40" LCD with a swiveling and removable mounting plate, 6x9 3-way speakers and a remote JVC deck with custom mounting plate(fake leather). All thanks to help from this site.
Here is my new problem. I noticed my new deck would not work with the batteries off. When I engaged the battery via a battery switch, the deck worked. Then I disconnected the batteries via the switch and it still worked for a minute.
I have been in an rv park for 3 months now and living off of external AC power. Should I be connecting the batteries via the switch once in a while for charging, or is something else wrong?
2003 28' Komfort.
Tsalla Apopka
Crystal River, FL
Posted: 09/15/11 07:41pm Link  |  Print  |  Notify Moderator
I think it's going to take a lot more information to answer your question. If all the items are a/c units they would run off the park power while plugged in to the shore or from the inverter that would be connected to the coach batteries IF that is what you have. With the coach batteries disconnected they will lose some charge but shouldn't be much if they are in fact disconnected.
I think the key is no matter what the arrangement you need to charge the batteries every so often.
Denny & Karen
Florida's Beautiful "Nature Coast"
Brit,TDI,BH & Claire,TDI (Belgian Sheepdogs)
Merlot - Sheltie rescue
Glady(Morgan Mare - retired),Toes & Beemer(Barn Cats-retired)
WA4OMG (Old Mangy Goat)
mram10
Everywhere
Posted: 09/15/11 07:48pm Link  |  Print  |  Notify Moderator
I have a battery disconnect switch in the trailer. I disconnect the batts when on external power. Should I connect the batts once in a while or should they charge regardless of switch position. Does this help?
Sorry, this is all new to me.
PapPappy
Wilmington, NC
Posted: 09/15/11 08:22pm Link  |  Print  |  Notify Moderator
If you look at the batteries, and see that the disconnect switch is the last thing to attach to them (no small wires), then the disconnect switch will keep them from charging. The power won't flow in either direction.
If there is a small wire also attached to the batteries, then you may have a charging connection, in which case they would charge any time you have power to the 110VAC, by way of the inverter/converter.
I don't quite know why the batteries would effect the television, unless you are not connected to 110VAC, or maybe there is a dead leg on a 50A service?? so those outlets are getting their power from the battery via the inverter?
I honestly don't think this is the case, as the transfer switch probably doesn't only switch half the connection.
I'm stumped too?
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
garym114
Bluff Dale, Texas
Posted: 09/15/11 08:32pm Link  |  Print  |  Notify Moderator
The deck is probably 12v and switches out when you open the disconnect.
If you want the deck to work close the disconnect. This will keep the batteries charged.
Not good to let the batteries discharge fully and leave them that way. Very short lifespan.
mram10
Everywhere
Posted: 09/15/11 08:38pm Link  |  Print  |  Notify Moderator
So, I have heard it is bad to leave the batteries connected while on external AC for long periods of time. Is that wrong?
Should I leave the batts connected for a couple hours a week?
pianotuna
Regina, SK, Canada
Posted: 09/15/11 08:53pm Link  |  Print  |  Notify Moderator
Hi mram10,
No, yes, and no!
If there is a modern three stage converter it may be acceptable to leave the battery bank connected except when the RV is in storage.
If there is an old converter that is single stage leaving the batteries connected for long periods of time may destroy them.
If it is an ancient converter the batteries may be essential to proper functioning of the converter, even though doing so may shorten their life span.
What make and model of converter is in your RV?
* This post was edited 09/15/11 09:50pm by pianotuna *
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
KendallP
Grants Pass, OR
Posted: 09/15/11 09:53pm Link  |  Print  |  Notify Moderator
My 1986 b-w (magnetek) 6300 series is left on 24/7 for months at a time. G27s never lose water. Golf cart jars might in the hot summer months, though.
Constant float is one of the best things you can do for your batteries. Leave the switch on, check the voltage often and electrolyte monthly.
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (with no payments)
korbe
Northern California
Posted: 09/16/11 08:43am Link  |  Print  |  Notify Moderator
I have a 3-stage charger but still use my disconnect switch when connected to shore power for a week or longer at a time. My batteries seem to lose water if left on the converter. For long periods of disconnect, I will connect the switch for about 24 hours each month.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
pianotuna
Regina, SK, Canada
Posted: 09/16/11 09:50am Link  |  Print  |  Notify Moderator
Hi korbe,
It may depend on the chemistry of the battery bank. Typically high antimonial content batteries such as golf carts loose 1% per day to self discharge. After a month they would be at about 75% of fully charged. Depending on the size of the bank (say 462 amp-hours?) that would mean over 115 amp-hours need to be replaced. at 13.2 volts that may take 168 hours. (one week)
If they are 12 volt marine batteries a similar size bank, when new, only self discharges about 1/2 that.
If they are AGM it is 1% per month--totally amazing!!!
