RV.Net Open Roads Forum: UPDATE: Report On Tetford Smat Sewage Hose.
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > UPDATE: Report On Tetford Smat Sewage Hose.
Lug_Nut
Victoria, British Columbia, Canada
Posted: 09/18/11 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a new sewage hose which appeared to be really heavy duty. The hose is close to rubber and is a very heavy wall thickness. You can stand on it and crush it flat without damaging its spape. It uses bayonet couplings of what look like quality design. I've used it for a couple of months. I've had issues getting it into the Newmar hose carrier tube as it wants to spring out. After a while it seems to relax and allow the hose door to shut.
Now it has developed an issue. It leaks from the coach connector end, where the plastic four lug piece grabs the four lugs. Looking art it, I see nothing wrong, but the sewage leaks by the seal that contacts the end of the adaptor. So, I looked up any issues people have had with them on the net.
Hmmmmmm...........Seems it has been a problem for ours too. They said they contacted Tetford and got no help only that they would have to buy another costly adaptor. The seal on this appears to become compressed in time and leaks.
Anyway, if you are thinking of getting one, be aware of this. I'm going to check out what I can do, and if I solve it, I will report back.
* This post was edited 09/20/11 12:50pm by Lug_Nut *
'07 Newmar Essex 45' ISM 500 4 slides
Shot-N-Az
Va
Posted: 09/18/11 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the report.
The Texan
Meridian, Idaho
Posted: 09/18/11 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried putting some silicone grease on the gasket? Might be enough to seal it....I have one, but have not used it yet. Thanks for the heads up.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
Lug_Nut
Posted: 09/18/11 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I cleaned the seal and looked to see if anything appeared wrong. When you install it on the four lugs you can feel it is not tight seated. The seal has become somewhat compressed, and in two months. That's why I did an internet search, to see if maybe there was a fix. Others had the issue also and got zero help from Tetford.
The Shadow Nos
East Peoria, Illinois
Posted: 09/18/11 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
I bought one in July when I traded coachs. So far they replaced one hose got a pin hole leak. Now I just talked to them last wed. they are replaceing the adaptor it is leaking like your.
2005 Allegro Bus
400 HP Cummins
2005 Jeep Liberty
pianotuna
Regina, SK, Canada
Posted: 09/18/11 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Go to a small printing shop that still does traditional printing. As them to sell you some rubber rejuvenatory. Bring a glass baby food jar.
Apply a few drops and use a disposable bristle brush to spread it around the offending seal.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Lug_Nut
Posted: 09/18/11 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
In as much as I've only had it two months, it should not fail in that short a time. Apparently I'm not alone. I'm considering cutting the hose (Though I hate to cut such a great quality hose) and installing a standard four hook adaptor.
Lug_Nut
Posted: 09/18/11 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
Certainly a great suggestion, but I shouldn't have to resort to this after paying about $100 for it two months ago. Additionally it would require constant repair. Thanks though for the geat idea.
exgman
Placerville, Ca.
Posted: 09/18/11 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
I bought the set up at the FMCA show in Albuquerque about 17 months ago. So far no leaks and it's working fine. My friend bought one too for his CC Inspire and the coach attachment was too long for it to work for him, so it doesn't work on all coaches.
Dan
06 Country Coach Intrigue
2012 Wrangler Unlimited Rubicon
fredbon
Pacific Northwest or SoCal
Posted: 09/18/11 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Looking at the reviews on the C/W website Reviews, leaking is a proplem.
Fred
Fred and Bonnie
Frankie & Scarlett, (The Cats)
2005 Dolphin LX 6375
2006 Saturn VUE
As I've Matured... I've learned that artificial intelligence is no match for natural stupidity.
