RV.Net Open Roads Forum: Truck Campers: Charger/converter upgrade?
 > Charger/converter upgrade?
Page of 5
2oldman
Winchester WA
Posted: 04/02/12 01:43pm Link  |  Print  |  Notify Moderator
almost the same post
shoreco
Long Island NY
Posted: 04/02/12 01:48pm Link  |  Print  |  Notify Moderator
billtex wrote:
JoeChiOhki wrote:
How many batteries do you have? If you only have 2, having really much above a 45amp is a waste of energy.
Hi Joe, I want to re-open this thread as I am ready to purchase the converter...likely today.
So 45 amp or 55 amp?
Tx, Bill
I just upgraded to a 9200 70amp...
Purchased it at adventurerv.net for big$$$ savings
Here is a link to pictures of my completed upgrade (took around 30mins)
http://www.rv.net/forum/index.cfm/fuseac........d/25852237/gotomsg/25860295.cfm#25860295
2002 National Dolphin 5355
cleary
Fairbanks, Alaska
Posted: 04/02/12 01:57pm Link  |  Print  |  Notify Moderator
cleary wrote:
cleary wrote:
We have the PD9260 in our rig and our Honda EU2000i handles it fine. I have seen it putting out 58 amps early in the re-charge. The Honda won't handle much of anything else at that point.
Chuck
Hi Bill,
Lots of good buys on EBAY That's where we got ours.
Chuck
An afterthought, make sure you use a wire size that will handle whatever amperage you decide on. I bought a high quality, arctic grade set of jumper cables, wire size #4 and used that wire between the converter and the batteries.
Chuck
2006 F-350, 4X4, Crew Cab, V-10, Torqshift, Dually. 2008 Okanagan 106UDB. Both 4-wheelers and snowmobiles. KL7AY Our website
JoeChiOhki
Sauvie Island, OR
Posted: 04/02/12 02:23pm Link  |  Print  |  Notify Moderator
Tx, Bill
55amp will charge somewhat faster, if your batteries can consume the available wattage. It will also charger faster if you rig consumes a fair amount of amps during regular use that would consume the majority of the available 45 amp output.
CB Channel 17 Redneck Express
billtex
RI
Posted: 04/02/12 02:33pm Link  |  Print  |  Notify Moderator
Tx, Bill
We are not big power users, except durring winter...when we would have a genny with us (Honda 2k) and are running an electric heater.
My main objective is quick charging from the truck alternator when on the go (not durring winter) when we do not have a genny with us.
Note; I am not planning on upgrading charge wire from alternator.
So 45 amp..or 55 amp?
Tx, Bill
2006 Chevy D/A CC
Adventurer 810WS
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
smkettner
Honda 2000 will easily drive the 45 or the 55 amp PD4600.
I would go big on the PD so 55 gets my vote.
675 watts solar
AnEv942
CA
Posted: 04/02/12 04:15pm Link  |  Print  |  Notify Moderator
Tx, Bill
Will there be any gain or differance between 45/55 amp - when from alternator supply?
Will the smaller unit limit or affect charge from alternator.
The only thing I remember reading was pushing more amps thru stock wiring that might be marginally small (older camper), but you seem to have addressed that (4ga). I think it was at Best converter...just curious
01 Ford 250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
billtex
RI
Posted: 04/02/12 05:05pm Link  |  Print  |  Notify Moderator
Tx, Bill
Yes...good question.
Tamnative
Mill Valley
Posted: 04/02/12 07:24pm Link  |  Print  |  Notify Moderator
Tx, Bill
I think your talking about 2 separate systems. The 45/55 etc. charger only charges the batteries when powered by an AC current such as the house or generator. The alt. charge from the truck is a completely different in as the batteries get there charge directly ( somewhat)from the alt. the same as the starting batteries in your truck. Unless of course an inverter that changes 12DC to 120AC has been wired in and your charger is plugged into that although I don't know if that would be of any benefit. Are any of you hooked up this way?
2005 Ford F-350 ex-cab Lariat 4x4 srw 6.0 Powerstroke
2008 Bigfoot 10.4
billtex
RI
Posted: 04/02/12 07:47pm Link  |  Print  |  Notify Moderator
Tx, Bill
So 45/55 amp would have no bearing on charging when we are on the road?
If this is the case...then 45 amp would make more sense as it would draw less power when running the genny (with the result that charge time would be slightly longer than with a 55 amp)?
Tx, B
Page of 5
