GARYWAVELAND
EUNICE LA.
On a 2004 Monoco Camelot 40' D/P there is a toggle switch at the door inside by the steps with the other switches that if you hit it the 12 volt system is shut down- well i hit it and it seems like the switch won't stay up I can hear it click outside but it is like it doesn't keep engaged is there something else that could be causing it or could it be a bad switch I am lost Please help Thanks
Spur Of The Moment
Quartzsite, AZ
It goes back to it's middle position. Push the bottom to turn the 12v off and push the top to turn the 12v on.
Nascar fans
Bruce and Sharon and Gizmo(Apricot Tiny Toy Poodle)
'07 Beaver Contessa Venice 43' Quad Slide
'01 Jeep Grand Cherokee
'08 Polaris Sportsman 500 Touring Quad on a HydraLift
'07 Joyner 1100 Sand Viper
bgum
South Louisiana
That is a 12 volt disconnect. Toggle it to store rather than use and then see if anything on 12 volts, such as lights, works. A click is about all you get in one of these. There is no other indication other than some have a small red light as an indicator.
sch911
Rochester Hills, MI
If it will not re engage you may have a bad battery isolation relay. This is what you hear clicking when you press the switch....
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
FeeLine
Middletown, NJ USA
You may want to check and see if the switch is bad, I have had to replace mine. I had shut off the 12 volt at the switch, and I could not get it to come back on. I replaced the switch and so far so good.
Paul & Ellen with Daphne & Digby 2006 HR Ambassador 40 PLQ, 2004 Jeep Liberty. F.M.C.A. F241322
Good Sam
John339
Clyde Ca. USA
That switch doesn't stay engaged.
That switch operates a heavy duty relay that latches to turn on the 12 volts.
When you push the switch down it unlatches the heavy duty relay and opens the 12 volts.
The switch is a momentary contact switch so it returns to the center position.
John and Cindy and Misty Rain and Senor Paco(Chihuahuas)
1994 Coachmen Catalina 300 MB RD
in sunny Clyde, Calif. KE6IDM
slickest1
canada
My coach has an on off switch by the steps for the 12 volt power. I had the same problem and there is a relay or solonoid in the rear electrical panel on the right side of the coach that was the problem. When I operated the switch it would just make a loud click in the elect. compartment. I first replaced the switch thinking that was the problem. So if it is not your switch it will be that relay. I was told it is a common problem with these things. Your switch may be different than mine so I would check that first. Good luck.
2000 H.R. Imperial 38wds rr8r roadmaster, isc 350 cummins
2007 Chevy Trailblazer, Blue ox towbar
Ready Brake with breakaway.
Wherever I happen to park
I have an intelletec battery control system.. Like you I have a switch just inside the door (2 of them in fact, one turns the voltmeter on if I press it, that's all, don't matter if I go UP or Down, it turns on the volt meter next to it, the other works as you describe)
The switches are DP3T 3-position on/off/on spring loaded return to center
The solenoid that actually connects or disconnects the battery is a "latching" type (magnetic latch) When I press the USE/STORE switch one way it causes current to flow one way in the solenoid, This "Switches" the think "ON" and a magnet holds it there.. Pressing the switch the other way causes current to flow the other way and another magnet latches it "OFF".
Sounds like you have the same system.
Nomadac
Columbus, IN
My switch is just like a light switch it is either on or off. They are very cheap switches and can fail. Sometimes I have to flip it several times to work. I also replaced it one time and now carry a spare.
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
2004 Honda Pilot w/SMI Air Force One Brake Sys.
1963 Pontiac Grand Prix 20' Enclosed Car Trailer
