outdoordb
Maryland
Looking to buy a new break controller. What's the best one ? I have been looking at Tekonsha PRODIGY P2 and P3. What's the differance between the 2 ( display ? ) I currently have the Voyager
downtheroad
Pacific Northwest
Either one...mostly display. Between the two, I'd go with the P3 simply because I normally go with the newest releases.
You will be sending money to everyone as a thank you who recommended the Prodigy over the Voyager.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Larryect
Home
I use a Brakesmart and absolutely love it. The thing that's great about it is that it senses the hydraulic pressure being applied to the vehicle brakes and send a proportional signal to the trailer brakes.
Unfortunately, they don't make it anymore. I understand the most similar unit now is the Maxbrake. http://www.maxbrake.com/ I don't have direct experience with this one.
wittmeba
Virginia
The main difference between the Prodigy P2 and P3 is the P3 has the ability to display amp draw to the brakes. This may only be useful if you know how to use it.
When all 4 brakes are working you will see amp draw of 10-14 amps. Amp draw changes with changes to the number of working brakes. Voltage does not. The voltage will display the same with 1, 2, 3 or 4 brakes working.
When 1 solenoid fails or you break a wire the current draw will drop. You need to know what you should expect (where it should read) and you can easily see that when you know they are all working.
As indicated MaxBrake may be a better choice. The difference between the Prodigy P2/P3 and MaxBrake is the brake demand sensing. P2 and P3 use an accelerometer and respond to tow vehicle deceleration.
MaxBrake taps into the Master Brake Cylinder and by an electronic pressure transducer converts brake fluid pressure to voltage. Maxbrake in my opinion is more directly tied to demands of the driver.
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
tvman44
Southwest Louisiana
I love my P3. Also a great trouble shooting tool.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
Chuck&Gail
In the Colorado Mountains
Almost anything is better than a Voyager. I threw mine in the garbage after one big trip. Love my Prodigy.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
md2lgyk
WV
I just replaced my Voyager with a P2. What a world of difference! When I bought my first TT, I didn't know anything about brake controllers, but should've figured the dealer would install the cheapest one he could.
"The great object is, that every man be armed. Everyone who is able may have a gun." - Patrick Henry
mkirsch
Rochester, NY
I actually have both the Voyager and Prodigy P2 installed in my TV.
The difference is night and day. I could never find a setting on the Voyager that wasn't slightly too much or not quite enough.
Put the Prodigy out of my old TV in, and didn't even change the setting. It was perfect.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
outdoordb
Maryland
md2lgyk, Same here did not know a thing about break controllers and the dealer hooked me up. You would think a good salesman would have sold us the best / most expensive one. Well, I just ordered mine through etrailers, got them to match the RV wholesalers price and saved about $15.00. can't wait to check it out.
Allworth
Orlando, FL
P3. (Someday you may upgrade to electric/hydraulsc disks. You will need it.)
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
