RV.Net Open Roads Forum: Tow Vehicles: Suburban Towing Performance
Search only in Tow Vehicles
 > Suburban Towing Performance
joedekock
West Michigan
Posted: 09/21/11 01:17pm Link  |  Print  |  Notify Moderator
Does anyone have any experience using a Bullydog or Hypertech performance system with a Suburban? I am curious if you notice the performance increases for towing a TT.
APT
SE Michigan
Posted: 09/21/11 01:26pm Link  |  Print  |  Notify Moderator
What year, engine? I hear good things about Blackbear tuning for late models.
Tuners seem to be good at improving shifting and power at WOT at higher engine speeds. They can provide a significant change in drivability at light loads in the city. You'll often read about them "waking their truck up". I don't hear much about improving towing performance, though.
2012 VW Passat TDI
ib516
Up here!
Posted: 09/21/11 01:31pm Link  |  Print  |  Notify Moderator
I've had really good luck with my Hypertech, but I drive a diesel.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
transferred
CA
Posted: 09/21/11 02:39pm Link  |  Print  |  Notify Moderator
Won't make much difference.
08 F450 Lariat CC 4x4, 4.30s
prev: F350 6.0 4x4, Chevy 3500 6.6 4x4, Dodge 3500 5.9 4x4
next truck: back to a srw one ton
Crazyfoe
Save your money they really don't improve much of anything. The torque management can be improved but the rest just doesn't measure up. There many other things I'd consider before that.
04' Chevy Silverado 2500HD 496 cu in - Allison
'06 Keystone Cougar 304BH
1 Honda eu2000i generator
Drawtight Activator
Huskey Weight Distribution System
1 Spazzed Weimaraner
skipnchar
Topeka or somewhere else
Posted: 09/21/11 03:03pm Link  |  Print  |  Notify Moderator
Gassers don't see much improvement with tuners except at the extreme high end of the tach and nobody likes down at high RPM. Usually the only differences that are really worth mentioning are if you tune and use premium fuel and while that MAY give you a little more kick it's a costly kick. Probably get more bang for the buck by changing gearing.
BenK
SF BayArea
Posted: 09/21/11 03:15pm Link  |  Print  |  Notify Moderator
What year Suburban?
GMT400's had a diesel option along with the 5.7L & 7.4L gasser
GMT800's had no diesel option and a variety of small blocks to the 8.1L big block
GMT900's (current offering) has no diesel option and a variety of small blocks
and NO big block
As noted, tuners work best or has the biggest increase with diesels. Gassers
will have to go to 91 octane and lower temp thermostat as the general rule.
What are you trying to fix?
-Ben Picture of my rig
joedekock
West Michigan
Posted: 09/21/11 06:45pm Link  |  Print  |  Notify Moderator
Thanks for the replies. I was curious if it the extra 14-20 lb. of torque would help at all with hauling a TT.
ordually
Castle Rock, Colorado
Posted: 09/22/11 01:09am Link  |  Print  |  Notify Moderator
I think my butt-dynometer would have a hard time feeling 20 ft-lb, towing or empty. A lot of tuners map a more aggressive throttle tip-in so it feels quicker when you accelerate (since, at a given pedal position, the engine in fueling more) but in the end don't dramatically improve.
Many Ford V10 owners have reported great experiences with the product and service from 5 Star Tuning. The owner, Mike, has a page up saying "coming soon" for GM gassers. You might give him a call, folks say he's great to deal with. I've not gone the tuner route so can't weigh in personally.
2005 F350 SRW V10 4.10 CC LB 4x4; BW Turnover ball; LineX
2011 Sequoia 5.7L 4.30; Tundra Towing Mirrors; LT 275/65R18 C Goodyear Wrangler MT/Rs on 2nd set of wheels
2005 Nash 22H TT
APT
SE Michigan
Posted: 09/22/11 08:17am Link  |  Print  |  Notify Moderator
I completely agree. Tuning the accelerator so that OEM 50% is now 25% really changes how a driver feels the power. But towing you spend a lot more time using the 50-100%, and the engine only has so much to give. Save the $500. 15-20 ft-lb is like 5%, not noticeable. And I doubt they can get that much from any naturally aspirated engine on the same octane.
Do you want more towing power? Gear swap is best for that. Again, year and engine would be helpful, and current axle ratio.
