RV.Net Open Roads Forum: Direct city line, or just fill up the freshwater tank?
 > Direct city line, or just fill up the freshwater tank?
MelinProv
Utah
Posted: 09/21/11 10:08pm Link  |  Print  |  Notify Moderator
Ive only used city water a few times but if I had a bigger rig or a family I would use it more.I boondock a lot and use the tank, I think Im just used to doing it that way now.
1775
NY
Posted: 09/21/11 10:19pm Link  |  Print  |  Notify Moderator
It really depends upon whether you are hooking up and your RV is staying put for several days or if you are using your RV as your vehicle during the day to tour the sites. We are traveling out in the RV every day and coming back at night. We fill the fresh water tanks at home before we leave and run off of them until they need to be refilled - then we refill them from campground water. It is enough to unhook electric every morning. We don't need to deal with putting away hoses too. If we were going to stay in the RV in one place and not move it out of the campsite at all, most likely we would hook up to city water.
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
filthy beast
New Mexico
Posted: 09/22/11 07:15am Link  |  Print  |  Notify Moderator
We use the city water hookup if we are not leaving early. If we need to pull out early we use the onboard tank so as to minimize any noise we might make in the morning getting ready to go. I also leave the fiver hooked up to the truck for the same reason, just unplug from the truck as I have never tested to see if there is a battery isolator on the truck.
Goody Two Shoes and the Filthy Beast
2008 Silverado 2500HD
2012 Wildcat 282RKX
1 Damnatian!
You cannot make things idiot proof, you can only make them idiot resistant.
retired in utah
Ogden, UT
Posted: 09/22/11 09:34am Link  |  Print  |  Notify Moderator
Good advice both ways. I keep about 1/2 tank of fresh water (50-60 gal)and use city water if it tastes, smells, and looks OK. I have had my share of foul-tasting city water and, like others, have been caught without city water for one reason or another.
2011 Ford F350 Dually
2011 Mobile Suites 36TKSB3
Reese 25K Hitch
Michelin 17.5 XTA Radials
brauneyz
Fulltime
Posted: 09/22/11 10:07am Link  |  Print  |  Notify Moderator
Are we the only ones whose pump rattles like crazy? Every 5er we've had has done this. For this reason, we always use city line when available and travel with 1/3.
frankdamp
Anacortes, or wherever we've gone.
Posted: 09/22/11 10:53am Link  |  Print  |  Notify Moderator
We don't have cross feed from the city hook-up to the potable tank, but the potable can't be gravity filled - it has a female hose-thread connection also.
We have some of the best nmunicipal water in the country in Anacortes, so we always leave home with the potable tank freshly filled. If we find the CG's water tastes weird, We shut off the city faucet and use tha tank/pump to fill a couple of jugs for cooking and drinking for the day. CG water then goes back on for potty, shower and sink uses.
I'm giving some though to getting a solenoid valve to put on the CG water inlet so I don't have to go outside to the pedestal to switch over.
Frank Damp, DW - Eileen
Anacortes, WA
'02 Georgetown 325, F53, V-10, bought used in 2010 at 13,000 miles.
Dogs - 2 Labs again, both yellow males, both 9 yrs old and both adopted.
bukhrn
Lanexa, Va
Posted: 09/22/11 08:30pm Link  |  Print  |  Notify Moderator
downtheroad wrote:
Full hook-up site...we always use city water.
Have a regulator and whole house filter.
X-5
2007 Forester 2941DS
2005 KIA Spectra
