RV.Net Open Roads Forum: Class C Motorhomes: What can my MH pull?
 > What can my MH pull?
nehuge
chandler, az
Posted: 09/22/11 11:07am Link  |  Print  |  Notify Moderator
1993 Coachmen, E350 with 360 EFI in it. GVWR is 11,500-12,000. Any ideas? I have a Malibu that is 3,100 pounds curb weight.
past-MIdirector
Michigan
Posted: 09/22/11 11:27am Link  |  Print  |  Notify Moderator
With a 360 I wouldn't want to try towing much over 2500lbs. Just the weight of the rig almost is max for that small of an engine. We had two rigs with Chrysler 360 engines and towed just a 18' boat which you could feel back there on every hill and stop light.
past-MIdirector
Michigan
Posted: 09/22/11 11:28am Link  |  Print  |  Notify Moderator
Dakzuki
Carnation, Wa, USA
Check the gross combined vehicle weight in your Ford owner's manual. Also check what your hitch is rated for (tongue weight doesn't matter but towing capacity will). Depending on GCVW you may have to travel with the RV loaded lighter to stay within limits.
2011 Itasca Navion 24J
2000 Chev Tracker Toad
nehuge
chandler, az
Posted: 09/22/11 12:44pm Link  |  Print  |  Notify Moderator
Sorry all typo.....it's a 460.
nehuge
chandler, az
Posted: 09/22/11 12:45pm Link  |  Print  |  Notify Moderator
I thought the owner's manual would have the combined reading based on an empty van before Coachmen puts the box on, not after so it would read differently.
tatest
Oklahoma Green Country
Posted: 09/22/11 12:51pm Link  |  Print  |  Notify Moderator
The Ford owner's manual should have a GCWR. With the 460, and standard gearing for the E350 cutaway, by the book you should have towing capacity for the Malibu. In the 90's the 460 was the biggest gas engine Ford made, had GCWRs in the 15,000 to 18,000 pound range for F-250, F-350 and E-350 cutaways.
Basic towing capacity of the chassis is GCWR - actual GVW (not GVWR). For a C, that might be limited by the hitch, but for delivery purposes Coachmen would have installed at least a 3500 pound hitch receiver for the driver's return vehicle.
It's when you have something a bit heavier than the Malibu, you have to start checking the actual weights vs. the numbers.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
stormrider54
Louisiana
Posted: 09/22/11 03:25pm Link  |  Print  |  Notify Moderator
try this
http://www.motorhomemagazine.com/Category/Dinghy-Towing/
* This post was edited 09/22/11 03:54pm by stormrider54 *
kaz442
NJ
Posted: 09/22/11 05:07pm Link  |  Print  |  Notify Moderator
How long is your MH? Whats it rated to tow? The rear frame and hitch can be beef up to tow anything within reason. Just stay within your GVCW. Shoud be around 18000#. My Rig had a 3000# max hitch, I changed the hitch and reinforced the rear rails and I tow my car and trailer at 5000# no problems.
JKaz
1989 26' Jayco class C E350 460cu
