redwake
Visalia, CA
balls do not *require* lube.
i put vasoline on mine because it helps it pop off the coupler when i unhitch.
TT: 08 Monterey 27 PT by Extreme RV
TV: 05 Eddie Bauer Expedition w/5.4L 3.31 Gears
Hitched with a Husky WD & SC.
Powered by Champion 3500
downtheroad
Pacific Northwest
wrote: balls do not *require* lube.
Are you sure...?
and isn't vasoline a lube?
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
rcase13
Charlotte
Apparently rust is an excellent lubricant. Most of the hitch balls I see are rusted completely. It's cheap and doesn't stain like grease does.
My ball is all shiny and new. I have looked everywhere and can't find it anywhere. Where the heck do you buy this wonderful product...
2013 Jayco Redhawk 26XS
opnspaces
San Diego Ca
redwake wrote: balls do not *require* lube.
That is true that hitch balls do not *require* lube, but it does help keep them from galling, pitting, and reduces wear. I towed my brand new trailer home from the dealer with a brand new hitch ball for a total of about 45 miles with no lube on the ball. When I unhitched the ball was a galled up mess. I always lube it now.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
redwake
Visalia, CA
downtheroad wrote: Are you sure...? yes
downtheroad wrote: and isn't vasoline a lube? yes
BarneyS
S.E. Lower Michigan
People don't "require" food and water either! All hitch manufacturers recommend using grease on the ball and the WD bars where they go into the hitch head. The ball will certainly function for a time without any lube, just like a person can function for a while without food and water, BUT after a while bad things start to happen.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
Chuck&Gail
In the Colorado Mountains
Have a friend who didn't lube TT ball ... until the day ball galled, stuck to coupler, and he found it had loosened the nut while driving. He is now a firm believer on lubing the ball. Your choice.
I use Reese ball lube or wheel bearing grease, depending on what I can find easily.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
tbrowne
Springfield, OH
Any lube will work, including wax paper. How can a person be so anal or a lube for a hitch ball?
Terry Browne
garysol
Avon Ohio
tbrowne wrote: Any lube will work, including wax paper. How can a person be so anal or a lube for a hitch ball?
How can a person be so anal? If your talking to me (the OP) I simply asked if the Reese lube was anything special. Please tell me whats so anal about that?
2008 Dodge Ram 3500 6.7 CTD SRW, Pullrite Superglide 18k.
2012 Komfort 3530fbh 5th wheel with Ground Control
redwake
Visalia, CA
but people do require food and water
