RV.Net Open Roads Forum: General RVing Issues: Squeeky table.... how to stop it?
 > Squeeky table.... how to stop it?
John S
Chicago, IL
Posted: 09/24/11 11:37am Link  |  Print  |  Notify Moderator
Our drop down table in our Class C seems to always squeek when we are driving and it can be quite annoying. I drop it down when I cannot stand it anymore but this is inconvenient.
I did spray the two bayonet like metal tabs that slide into the wall brackets with silicone spray and this helped for awhile but it is not a permanent solution.
I was wondering if anyone has come up with some better ways to stop the table squeek problem?
I was thinking that something like some thin silicone type sleeves that could fit over the table tabs and into the wall brackets would be a possible solution. Wonder if anyone makes anything like that?
What suggestsions are out there? Appreciate any and all suggestions.
John & Peg S.
99 Coachman Class C - 24ft
camperpaul
Wherever I park my travel trailer
Posted: 09/24/11 02:24pm Link  |  Print  |  Notify Moderator
John,
Make a couple of wedges out of HDPE...
A good source of this material is "One Gallon" water jugs.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
oldchief7155
VA
Posted: 09/24/11 02:27pm Link  |  Print  |  Notify Moderator
Wedges rubbed with bar of soap.
camperpaul
Posted: 09/24/11 02:32pm Link  |  Print  |  Notify Moderator
If the wedges are made of HDPE, you won't need the soap; it's self lubricating.
wannavolunteerFT
South Georgia
Posted: 09/24/11 03:35pm Link  |  Print  |  Notify Moderator
don't know about your class C, my TT manual recommends traveling with table in bed position
oldchief7155
VA
Posted: 09/25/11 02:45am Link  |  Print  |  Notify Moderator
Thanks Paul. I just finished my entry when you said milk jugs. I like it better than wooden wedges.
John S
Chicago, IL
Posted: 09/27/11 12:10am Link  |  Print  |  Notify Moderator
The milk jug wedges sounds like a clever solution. Will give it a try.. Thanks... Prefer to keep the table in the up position if we can as it is more convenient for when we stop or when someone wants to sit in the nook area, etc... Thanks again for the suggestions.... John S.
Gjac
Milford, CT
Posted: 09/27/11 06:41am Link  |  Print  |  Notify Moderator
I tried a number of things to stop the squeak including wedges. The wedges worked but I was always losing the wedges when I put the table down to make the bed. I ended up gluing compressible foam strips to the back edge of the table. So far so good.
