RV.Net Open Roads Forum: Technology Corner: composite to HDMI
 > composite to HDMI
duane124
planet erth
Posted: 09/25/11 11:27pm Link  |  Print  |  Notify Moderator
per my instructions that came with my 32 inch vizio lcd tv e320va that does not have a set of separate yellow red white input connectors
"you can use your hdtv component input to accept A/V(composite)from a source with A/V out(in this case your sat reciever). please plug your video signal(yellow connector) into the component input(green connector) and match up the audio connectors(left is white connector and red is an right connector) for the sound..expect to see a black/white video in the component input if its selected by accident"
if im reading your original post correctly, your trying to get standard composite (Y,r,b connectors) to connect to component
betcha an internet dollar this i what your looking for(instruction wise)
there is no need to buy anything adaptor wise unless you want to throw money away and if you do, ill just send ya my addy
here is the image
yellow goes in the green connector with the Y under it...audio in is straight forward
and explains how the kids hooked up the Xbox360 and then a DVD player to this tv with the standard Y(video) and r and b(audio) off the xbox and DVD player
* This post was last edited 09/26/11 12:26am by duane124 *   View edit history
stevo75
Massachusetts
Posted: 09/26/11 05:05pm Link  |  Print  |  Notify Moderator
This is what you need and it will be upconverted to 1080P and is HDCP compliant. Very expensive for what it's doing at 300 bucks and I suggest just upgrading SATV box.
There are many more in Pro AV industry but these guys are probably the cheapest while making a good product.
http://www.atlona.com/Atlona-Video-and-S-Video-Audio-to-HDMI-Converter-Scaler-up-to-1080p.html
2007 Jayco Jayflight 31BHDS (at seasonal in Maine)
1995 Trophy 2302 offshore fishing boat
SCVJeff
Santa Clarita, CA.
Posted: 09/27/11 12:48am Link  |  Print  |  Notify Moderator
It's still 480 no matter what format light comes on at the output. Still cheap for what it does..I might by a few and see how they stack up against the AJA and Black Magic's we use around the studios
Jeff - WA6EQU
Todger
Newville, Pa., USA
Posted: 09/27/11 02:15pm Link  |  Print  |  Notify Moderator
Thanks for all the input. I went back to the specs and found they use the green component plug for the composite video (yellow) input.
LarryJM
NoVa
Posted: 09/27/11 03:56pm Link  |  Print  |  Notify Moderator
Todger wrote:
I'm aware that the signal will still be SD but I will be able to plug the HDMI cable into the TV. I'm sure there is no composite inputs. All new HDTV's have component and HDMI inputs and no composite.
The 42" LG HDTV I just bought 2 months ago has 3 HDMI, 2 component, and two composite inputs so there are newer TVs out there, but they are getting harder to find.
I ran into this same issue since my 1990's Sony Sat2 Satellite box only has composite output and inputs. Also, I tried to use the HDMI TV input for my Panasonic DVD/VCR recorder and found out that when I turned the TV on it automatically turned the DVD/VCR recorder on and would negate any programming. Thus I had to revert back to component connections between those two.
Larry
* This post was edited 09/27/11 04:03pm by LarryJM *
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
stevo75
Massachusetts
Posted: 09/27/11 05:07pm Link  |  Print  |  Notify Moderator
built in scaler spits out 1080P signal receiving TV or display recognizes it as 1080P during EDID (oops I meant TMDS)translation, if it was 480 then the display would show 1.33/1 or 4:3 aspect ratio. I do like AJA. TV One makes a good product and then there's trusty old Extron.
AJA is expensive and a great product.
Check out Miranda also.
Been a while I worked in TV production (Ex TV Truck Engineer. Now I design and engineer these things.
* This post was last edited 09/27/11 05:41pm by stevo75 *   View edit history
SCVJeff
Santa Clarita, CA.
Posted: 09/27/11 06:33pm Link  |  Print  |  Notify Moderator
I figured... Not too many that can spit out those acronyms.. I won't use AJA just because I won't pay $50 for a wall wort the others supply for free. We also had issues with AJA HD>HDMI not liking Evertz VIP jitter, so we want to Black Magic.. So far so good. I thought it was EDID, but I'm not the protocol guy If AFD was a reality that's all one would need.
Back to the thread>
duane124
planet erth
Posted: 09/27/11 11:44pm Link  |  Print  |  Notify Moderator
no sweat...glad i could help
 > composite to HDMI
