RV.Net Open Roads Forum: Dinghy Towing: Another junk supplemental brake
Search only in Dinghy Towing
 > Another junk supplemental brake
4gone
Mass
Posted: 09/26/11 06:34pm Link  |  Print  |  Notify Moderator
In your description of your test procedure I notice you didn't mention pushing the test button. With mine, before you plug the unit in at all either to the signal box or 12v yet your toad set up, neutral, key in the right position, etc. Plug in the Data cord, plug in the 12v cord, compressor will run, push test button. It will pump 3 times and you will get a green light. The order seems very important, and if it is hooked up and I do something with the key it will act up sometimes, no idea why. Other than a couple of times it has worked fine in the five years I've been using it.
2007 Damon Daybreak 3276
2010 Suzuki Grand Vitara
Even Brake
XM Radio
Direct TV crank up dish
Firestone air bags
Blue Ox Alladin tow bar
Hankook Tires
DrivingMissDaisy
Myrtle Beach SC
Posted: 09/27/11 04:12am Link  |  Print  |  Notify Moderator
I went thru several test procedures with Roadmaster Technical service yesterday. They're sending me a new unit.
See you down the road!
Larry
2000 Winnebago Adventurer
20,000lb F-53 w/ 310hp Triton V-10
towing: 2003 Jeep Grand Cherokee
towing gear, Blue Ox
mgh122
PA
Posted: 09/28/11 12:53pm Link  |  Print  |  Notify Moderator
I've put close to 30k on an M&G, self installed. Nothing to go wrong.
Mike & Peg
Aint' life grand!!
'05 Discovery 39S
'04 Grand Cherokee Freedom, M&G, Roadmaster Sterling
http://discovery-on-the-road.blogspot.com/
Zeus the Wonder Dog
"makes you wonder doesn't he"
Geozzz
South Jersey
Posted: 10/04/11 05:39am Link  |  Print  |  Notify Moderator
We have and are using the Evenbrake for quite a while now and are very happy with it.The only problem we ever had was running the toad engine after evenbrake was installed. This caused a momentary brake lockup at the first stop street.I now know you must run a test after running the engine to release the built up engine vacuum.
Kathy & George Zimm
Mickleton NJ
2006 Coachman Epic and 2011 Chevy Equinox toad
2 Shelties
rockhillmanor
On the Road
Posted: 10/04/11 05:55am Link  |  Print  |  Notify Moderator
mowermech wrote:
There IS a simple, relatively inexpensive solution:
Go to Night Shift Auto (NSA) and order the ReadyBrake kit.
It is a little over $400. A little over $500 if you get the accessories to go with it. It will work with your existing towbar.
IMO, it is the ONLY supplemental braking system that makes sense!
I so desperately want to ditch my BB.
Tried looking up ReadyBrake and I am not sure which one can be used with blue ox tow bar. I'd like not to have to buy another tow bar.
Is THIS what you are talking about?
http://www.readybrake.com/brake-systems.html
"We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us".
DrivingMissDaisy
Myrtle Beach SC
Posted: 10/04/11 06:11am Link  |  Print  |  Notify Moderator
I had Roadmaster send the replacement Evenbrake to my next stop. I've been delayed so have not gotten it yet. I will update with results asap.
rvarner
Pahrump, NV, USA
Posted: 10/07/11 07:28pm Link  |  Print  |  Notify Moderator
I have one and it works perfectly. Call em, they are very helpful.
Richard
2002 Itasca Horizon 36LD/2008 Xterra/DEMCO Xcali-bar/Ready Brake
FMCA 394912
Pixguy
NH & FL
Posted: 10/09/11 05:29am Link  |  Print  |  Notify Moderator
Yup, that's the one.
Love the system!
2007 5320LX NRV Dolphin on Ford Chassis
2010 CRV Toad w/ Readybrake system
DrivingMissDaisy
Myrtle Beach SC
Posted: 10/10/11 02:03pm Link  |  Print  |  Notify Moderator
Replacement EvenBrake was waiting for me at my destination, I haven't towed with it yet, but it powers up and passes the self test. It looks as is all is well. For $1000 it should have worked out of the box, but stuff happens and I have to give Roadmaster tech support credit for not messing around and sending me a new unit right away.
restorodder
Pinckney Michigan
Posted: 10/13/11 05:26pm Link  |  Print  |  Notify Moderator
Mowertech is right,Ready Brake-Ready Brute is the only system that makes sense. No electronics to fail,no hydraulics,no air lines to hook up or fail. Why would any one want to spend an extra $1000. on something that has a high failure rate?
2008 Newmar Canyon Star - 2007 Dodge Dakota Toad - Ready Brute tow bar & brake system - one cat - Sassy 14
