RV.Net Open Roads Forum: Tech Issues: More Boondockery
 > More Boondockery
Page of 17
mena661
Posted: 09/25/11 08:17pm Link  |  Print  |  Notify Moderator
Finally, got out for a real live boondock trip with my setup (see HERE)!! DW and I did a test run a month ago which went well (HERE). First victim was Point Magu State Beach (Thornhill Broome).
This was a relatively primitive campground. There was water and some porta-potties but that was it. Power usage ended up being a bit more than the previous overnighter but still well under my projections. Watching TV via the inverter was the largest power drain. We watched about 3 hrs the 1st day, 4 hrs the 2nd day and 2 on the last. It was a mix of pre-recorded shows on DVD and sat. Overall usage was as follows:
1. Left home at 12.81V which is 100% SOC for us (98F/37C). Arrived 3 pm-ish on Fri (79F/26C).
2. Sat morning at 12.75V, 95.6% SOC and -45.1 Ah (64F/18C).
3. Sun morning at 12.65V, 87.6% SOC and -125 Ah (62F/17C).
4. Arrived at home ~2:30 at 12.63V, 85.2% SOC, and -148 Ah (88F/31C).
All the numbers are taken directly from my Victron battery monitor. Because of the wildly varying temps between here and the beach, verifying the SOC on the meter was impossible for me. If I went by voltage using Trojan's chart, the ending SOC would be 90% which I know isn't right because they consider 12.73V 100%. Using the Ah removed would put me at 80% which isn't right either because the battery capacity changed during our 2.5 hr drive home. Maybe next time I'll take the hydrometer.
Trojan L16 6V's 740 Amp-hours
hypoxia
Arizona
Posted: 09/25/11 08:34pm Link  |  Print  |  Notify Moderator
That's the best way to camp. Shouldn't your camper charge from the truck driving home?
Jim
2007 Monaco Signature Noble III ISX 600HP
mena661
Posted: 09/25/11 08:40pm Link  |  Print  |  Notify Moderator
We had a great time! [emoticon] The DW and I have been looking forward to this for quite a while. The truck is supposed to be charging but it's not working. Apparently I only need a fuse and there's one installed but I just haven't troubleshot it yet. It would be nice to have it working if only to arrive at the campground at 100% SOC. Even with it not working, I'm only out a few Ah.
skipnchar
Topeka or somewhere else
Posted: 09/25/11 08:58pm Link  |  Print  |  Notify Moderator
For what it's worth, Ford takes both a fuse and a relay.
Good luck / Skip
mena661
Posted: 09/25/11 09:02pm Link  |  Print  |  Notify Moderator
Good luck / Skip
Thanks, I'll check for the relay.
KendallP
Probably the office
Posted: 09/25/11 09:46pm Link  |  Print  |  Notify Moderator
From your Sunday morning figure, it looks like you use about 8% a day. At that rate, you could do a week without the genny.
Peukert is your friend. Capacity is king!
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (Don't laugh...
Unlike our credit cards... she's paid for)
pianotuna
Regina, SK, Canada
Posted: 09/25/11 09:54pm Link  |  Print  |  Notify Moderator
Oh the joys of a large battery bank are many! Keep on letting us know how the system is working!
Regards, Don
Full Time in a 28 foot Class C, 256 watts solar, 556 amp hours of AGM in two battery banks 12 volt batteries, 3000 watt Magnum hybrid inverter, Sola Basic Autoformer, Microair Easy Start.
mena661
Posted: 09/25/11 09:57pm Link  |  Print  |  Notify Moderator
And that's just down to 50%!! Friggin awesome!
You bet PT!
time2roll
Posted: 09/25/11 10:50pm Link  |  Print  |  Notify Moderator
Since you do not have any issues leave the hydrometer at home.
675w Solar pictures back up
revump
Deer Park, WA or Las Vegas, NV
Posted: 09/26/11 08:34am Link  |  Print  |  Notify Moderator
What a great way to spend your time. We try to do that on a regular basis. We FT
Bob
Page of 17
 > More Boondockery
