Pirate
Appalachia
dsbsi wrote: 1995 was the last year for the ODB I.
Topflite is correct on the location of the ODB II access plug. It is pushed up into a protective cover and must be pulled down to plug the ODB II into the connector.
Dwight Wrong. The F-53 with the 460 had EEC-IV, no OBD-II. V-10 Ford started using OBD-II.
RLS7201
Some Where
Dwight
Ford never went to OBD II on the 460, except for a few 96-97 California pick ups and vans.
Richard
tommy g
West Georgia
I also have a '98 Bounder with a 460 v8 and had the same problem. After going 'round-the-world with codes and thinking it was the EGR, I finally found an unplugged vacuum hose. Look for the simplest items first.
Chuck_NJ
New Jersey
I am a ASE auto tech. I have a 94 bounder with 460. It has obd1 like yours and had the conector just like the photos 96bounder showed. Mine had the on and off check engine light turned out to be broken platic vaccum hose that ran fron the passenger side of the engine down to just to the right of radiator to the plastic vaccum reservoir. It was setting egr and air injection codes the reservoir supplies vaccum to both the egr and air injection solenoids
dsbsi
Minnesota
1995 Bounder Ford 460 2007
Same problem at the same right front location. on/off light same codes.
Dwight
1995 Ford F53 Bounder 35U
Cold Spring Minnesota
slowdown1
Fontana
Thank you for the picture it has been most helpful as I have no experience with orb I reader anyone has any suggestions where to find /purchase one. I have a odb II reader is there such a thing as a plug converter? Also thank you for the suggestion about the air filter I have not cleaned / replaced it it for a year or over 1000 miles. I Have not checked for they oil pressure will check on that as well. How Manny o2 sensors are there on a 97 engine? I washable to find the one Mounted under the passenger seat on the manifold. Is there anotherone?
slowdown1
Fontana
slowdown1
Fontana
Thank you for the responses specifically thank you for the picture I am going to check on all the suggestions starting with the air filter is been 1 year and over 1000 miles since I cleaned my k&n filter in addition I need to check on the oil pressure, unfortunatelly i only have a odb II reader do the make an adapter? I just ordereda odb 1 reader from eBay I will report on the results thank you all for all the responses and suggestions, your time is appreciated!
Jim@HiTek
Gresham, OR, USA
I see you've already ordered an OBD I reader...but for others reading this thread, note that you can borrow or buy a reader from many automotive parts supply chain stores.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
Nick-B
Vaughn, WA
Hi Slowdown1,
Best of luck tracing down your issues.
To answer at least one of your questions - The 460 only has the 1 O2 sensor which you have already discovered.
Nick
1995 Coachmen Santara MB360 w/slide
F53/460 chassis w/tag
