RV.Net Open Roads Forum: Travel Trailers: Backing TT into storage stall
 > Backing TT into storage stall
jhocksrule
Topeka
Posted: 09/26/11 08:31am Link  |  Print  |  Notify Moderator
I have a 2011 24' TT that is about 8' wide. I have a storage spot that is 10' wide with another TT on one side of me. On the other side is a pole dividing the stalls. I got back yesterday from camping for the weekend with it and had a heck of a time backing it in to the stall. Any suggestions on ways to approach the stall for easier time backing it in?? There is stall across from me to so I CAN NOT pull in and straighten up to back it in. It's pretty much a jack knife job to back it in. Any help or suggestions would be GREATLY appreciated.
Akeru
Oregon
Posted: 09/26/11 09:18am Link  |  Print  |  Notify Moderator
I have to park my trailer on the side of my house. I have 10 feet. I have house and utilities on one side and a rock wall on the other. I do have a utility box thrown in there for added stress. I found this video and applied the technique...and it has worked for me! Maybe it will help you.
Good luck!
http://youtu.be/RLtfrBWzNCw
lanerd
Newport, OR
Posted: 09/26/11 09:23am Link  |  Print  |  Notify Moderator
I suggest that you go down to the local walmart or other large parking areas and mark off a spot the same size as the garage and practice, practice, practice. You will develop your own procedure. You'll be surprised as how quickly you will find your technique.
Hope this helps
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
mobeewan
Hampton, Va
Posted: 09/26/11 09:36am Link  |  Print  |  Notify Moderator
I front hitch for the TV might help for tighter maneuvering.
jhocksrule
Topeka
Posted: 09/26/11 09:52am Link  |  Print  |  Notify Moderator
Akeru, I've watched that video before. I don't have enough room to "SCOOP" in towards my spot. There isn't enough room for me to straighten the TV and TT up to back it in from a more straight on position.
dalehelman
Liberty Lake (Spokane) Wa.
Posted: 09/26/11 10:13am Link  |  Print  |  Notify Moderator
Practice, practice, practice it is an acquired skill.
Dale & Sandi
2006 Jeep TJ 4.0 w/33s 4" lift
2008 Winnabago Adventurer 38T
Liberty Lake (Spokane) WA.
DIY Manual replacement for Workhorse Auto Park emergency brake.
Stay In Play Duo Toad Braking System
skipnchar
Topeka or somewhere else
Posted: 09/26/11 11:43am Link  |  Print  |  Notify Moderator
Another suggestion to spend time practicing backing. Until it comes as natural to you as driving forward it won't be as much fun as it could be. Much better to learn to back with proficiency than to use a front hitch. You may need to back up most ANYWHERE you go and can't always unhitch and turn around.
BarneyS
S.E. Lower Michigan
That "scoop" is just the first half of the "S" maneuver! If you do the "scoop" just turn back towards the other side so your trailer rear is pointed at the entrance to the site and your truck front is pointed at the site to the drivers left side. This will allow you to back in without having to have the truck and trailer lined up almost straight like he did in the video.
This works great in narrow streets or in campgrounds with other vehicles blocking your way in narrow roads.
See my post here for step by step instructions.
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
mpfireman
Cook County Il
Posted: 09/26/11 11:45am Link  |  Print  |  Notify Moderator
Have you ever seen these ad's that feature an electric type dolly that will maneuver trailers around? These are featured in many RV type magazines. Also some people have a ball type hitch mounted in the front of there TV just that purpose of parking their trailer.
1998.5 Dodge Ram Quad Cab Cummins
1998 Sunnybrook 27RKFS Fiver
JN_B
Calgary, Alberta
Posted: 09/26/11 02:21pm Link  |  Print  |  Notify Moderator
I'm not sure how to explain this, but I find it easier (if possible) to approach the stall with the driver's side closest. then you can watch the obstruction (wall) either with the mirror or over the driver's side shoulder. Exactly how the video shows..
And practice practice practice..
2003 GMC Sierra 1500HD SLT
2010 K-Z Spree 318BHS
