RV.Net Open Roads Forum: How to build a gravel RV pad
 > How to build a gravel RV pad
Shot-N-Az
Just South of DC
Posted: 09/26/11 06:57pm Link  |  Print  |  Notify Moderator
Hi folks,
I seriously need to build a pad for my RV. I want to use gravel and it will be built on clay soil. It's a 40' DP, so it's a lot of weight to support.
I know squat about the "how". All I know is the "what". What can you folks tell me about what is involved and how to proceed?
PapPappy
Wilmington, NC
Posted: 09/26/11 07:09pm Link  |  Print  |  Notify Moderator
You will want to have the space dug out about 6-8" for the length and with of the space you want to park the RV.....and the "driveway", if you want that to keep from sinking in raining weather...
Depending on the location, you may or may not have to install drain tile(pipes) to get water away from the area.
Once you have the area excavated and level, you have a load of sand or very small stone laid down for about half the thickness.....follow that with the stone you want to finish with. The small stone will keep the large stone from just sinking into the clay.
Another option might be to put up some 2x6 boards down the side of what you want to "pave", and then fill in with stone, as mentioned above. This saves you the hassle of excavating....but also keeps grass and such from being elimiated by excavating, so you would need to spray to kill any weeds and such.
A third option, depending on your situation, would be to have some concrete pads installed where you plan to park the RV.....figure out where the tires will sit, and then have some re-enforced concrete pads made that are a bit larger than the tire "footprint", and have those poured in place....again, probably about 6" thick. This is what I plan to do with our MH. I'll probably dress the rest of the area with stone....but the MH will sit on concrete!
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau ">
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.">
Purchased April 2008"> FMCA# F407293
The Pets
pigman1
Delaware
Posted: 09/26/11 07:26pm Link  |  Print  |  Notify Moderator
2'x2' concrete pads 8" thick with 6 pieces of 1/2" rebar within 1" of the bottom supported my jacks on the Allegro bus. We stored the Bus with all weight on the jacks and the tires just barely on the ground.
John
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
jliveit
ohio
Posted: 09/26/11 07:39pm Link  |  Print  |  Notify Moderator
I just used a good base of Berm followed by thin layer of gravel. Berm is what they use along road sides, the berm of a road and is a mix of really crushed limestone and larger limestone and it packs very hard. All my ground is clay and after 4 years I have done nothing to it.
conmoto
Northern Illinois
Posted: 09/26/11 07:58pm Link  |  Print  |  Notify Moderator
I just had one installed for our 5th Wheel. 12" deep filled with larger rock on the bottom and then filled with smaller on top then rolled. Came out nice and will hold the weight of a large RV.
Bob/Olallawa
Kitsap Co, WA
Posted: 09/26/11 08:09pm Link  |  Print  |  Notify Moderator
Keeping the water away from the area is a must if the soil is clay. By the time you dig out and then put in a good base course and the finish course on top you would almost be close to the cost of going with a reinforced concrete pad. Over time the concrete will hold up much better than a gravel pad.
Welcome to my home, that door you just broke down was there for your protection not mine.
pitch
NY
Posted: 09/26/11 08:17pm Link  |  Print  |  Notify Moderator
IMHO You need to dig at a minimun to just below any organic matter. I went 10". laid Geotex fabric. I used run o crush limestone,#2's down to stone dust,heavey on the dust. Tell your Quarry or trucking comapany that you want from the bottom of the pile. more dust and fines will make it all lock together for a real firm surface. If the truck has good access(no overhead wires!)a good driver should be able to do a decent job of speading it for you leaving only a minimum of hand finishing to do. Wet it all down real well and start rolling it.(if you don't have a lawn roller you can drive over it repeatedly moving your tires across it as you go.) You are now the proud owner of a lifetime RV pad.
jolooote
Miami, FL
Posted: 09/26/11 08:25pm Link  |  Print  |  Notify Moderator
I made my own 4 concrete pads for the tires. Pads are 2.5 x 2.5'.
I'd NEVER do it again!!! Working with bags of concrete mix by hand is some SERIOUS work...bleeding fingers and all the weight! 4 ea. 80# bags per pad. I'd hire a full pad (berm)of fine crushed & hard packed limestone delivered. IMHO.
Joe & Charlotte, 2015 Thor Vegas 24.1 Ford E-350 305hp V10 5speed, Jeep Wrangler & Honda Element 'TOADS'
Rosie, Morky Dogs
Leroy's a Conure
"Once it starts breakin'...GET RID OF IT!"
Tsalla Apopka
Crystal River, FL
Posted: 09/26/11 09:05pm Link  |  Print  |  Notify Moderator
In WV where it's all clay we did a driveway about 600 feet long and just graded it to a slight dome, laid down a layer of heavy landscape cloth and covered that with quarter size gravel spread by truck. Swales were put along both sides also to take the water away.
That was in 1996 and the driveway is still used every day to access the Equestrian Center that we had built.
Denny & Karen
Florida's Beautiful "Nature Coast"
Brit,TDI,BH & Claire,TDI (Belgian Sheepdogs)
Merlot - Sheltie rescue
Glady(Morgan Mare - retired),Toes & Beemer(Barn Cats-retired)
WA4OMG (Old Mangy Goat)
conmoto
Northern Illinois
Get some quotes before you believe anything being said here about price.
