RV.Net Open Roads Forum: Power inverter question .
 > Power inverter question .
chain
Pecos
Posted: 09/28/11 12:27pm Link  |  Print  |  Notify Moderator
My last inverter went up in smoke .
Not sure if I did it so I wanted to know if this is ok to do .
I have 2 aux batteries but they are not strong enough to power my microwave
for any time .
So if I get a new inverter and hook it up to the batteries (that have a charger on them to
charge when van is plugged in or when engine running) and when camping with no power
start van and plug micro into inverter to run .
Will this work ? Should this work ? Could this work ?
Thanks .
Chain
Fire Instructor
Upstate (Albany) NY Area
Posted: 09/28/11 12:42pm Link  |  Print  |  Notify Moderator
My microwave is a 900W draw. My Xantrex inverter (1800W) will power it, but not for long, as I only have 220AH of storage. To power an inverter big enough to run a MW for any length of time you either need much more storage, a VERY big alternator, or a 120v generator. You also need to size the cables from the batteries to the inverter appropriately large to carry enough current. I did my solar system (300W), the 1800W Xantrex, and the 220AH of battery so that could run everything EXECPT the MW and the A/C off of batttery.
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
300 Watts of SunTech Solar Panels
Rogue MPT-3024 Controller & Xantrex PW2000 Inverter
"If everyone is thinking alike, then someone isn't thinking!" General George S. Patton
chain
Pecos
Posted: 09/28/11 12:52pm Link  |  Print  |  Notify Moderator
Then I just don't get what use an inverter is for me .
Don't run a fan , computer or anything like that from it .
Just wanted to be able to heat up something when no power is available .
Thanks for the info .
Chain
hotrod4x5
Southern Calif
Posted: 09/28/11 01:24pm Link  |  Print  |  Notify Moderator
Microwaves are picky. I have a Xantrex 2000 watt and I can run the microwave, but it doesn't run at full power and not for very long.
What do you need to heat up that the stove/oven won't handle?
Rodney 2005 Laredo 29GS 2002 F250 V-10 Yamaha EF3000iSEB (and NOT a GS Member)
pianotuna
Regina, SK, Canada
Posted: 09/28/11 01:32pm Link  |  Print  |  Notify Moderator
Hi,
Are those six volt batteries or twelve volt?
My "wave" draws a whopping 1591 watts.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
chain
Pecos
Posted: 09/28/11 01:34pm Link  |  Print  |  Notify Moderator
I do bike shows In New mexico (HOT) and it's just easer to Micro then use
the stove .
chain
Pecos
Posted: 09/28/11 01:35pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
There 12V
bananadanna
Cambridge, MA
Posted: 09/28/11 03:44pm Link  |  Print  |  Notify Moderator
If you want to use a microwave then plan for it.
My micro (650w output, 1100w input) works great off my 2000w psw Prosine 2.0 inverter and 440 ah bank. Xantrex recommended a bank greater than 400 ah for that size inverter. No need for shore power or engine idling. A big bank will limit the voltage drop from a 100a draw. A big voltage drop will shut down many inverters.
Buy a Kill-a-watt meter (often $20 on sale). Some libraries have them to loan for energy conservation. Measure the draw of your micro.
If you cheap out and buy a non-psw inverter then the micro may not work properly or take longer. Micros care about waveform more than most devices.
A different option is to use a magnetic induction burner (Sunpentown, $120) if you want half the waste heat as a propane burner. You still end up with a pot to clean. Actually a great complement to a micro if you do get the 400 ah bank.
Otherwise propane can't be beat for lots and lots of btus. We carry a bbq tank in a propane locker and find a propane bbq grill can do what a micro and cooktop can't. So many great compact campstoves if you want to keep the heat out of the van.
Dan
02 Freightliner Sprinter 2500 long tall home brew conversion
1775
NY
Posted: 09/28/11 03:53pm Link  |  Print  |  Notify Moderator
There are two things that I have been advised not to run from my inverter - the microwave and the A/C - both will work but will drain the batteries fast due to the amount that they draw. I run the TV, ceiling vent fan, lights, laptop computer, home entertainment unit and other small appliances plugged into 120 volt outlets in my Class B on the inverter with no problem. If all you want to do is heat something up you would be better to use your propane stove or consider adding a generator into your system to run your microwave.
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
pianotuna
Regina, SK, Canada
Posted: 09/28/11 05:17pm Link  |  Print  |  Notify Moderator
Hi,
Are they wired in a balanced manner? How many amp-hours in total?
