RV.Net Open Roads Forum: How do you remove dicor roof sealant and type of cleaner?
 > How do you remove dicor roof sealant and type of cleaner?
Rock2
PA
Posted: 10/01/11 07:37am Link  |  Print  |  Notify Moderator
Next week I plan to work on dome skylight that needs to be replaced. There is sealant around the edge of the skylight. I am trying to see how I get those old sealant off and what kind of cleaner before I install a new skylight. I am aware that there is some of cleaner may have petroleum and may damage rubber roof. Any advise would be greatly appreciate it. Thanks!
downtheroad
Pacific Northwest
Posted: 10/01/11 08:10am Link  |  Print  |  Notify Moderator
Try a heat gun or maybe a hot hair dryer...soften it up and GENTLY scrape it with whatever flat bladed tool you have around..
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
zigzagrv
Nazareth, PA
Posted: 10/01/11 08:32am Link  |  Print  |  Notify Moderator
Mineral spirits will remove Dicor residue. Don't know if it's ok for your rubber roof though.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
Master Tow dolly
Toyota RAV4
Ron3rd
Upland, CA USA
Posted: 10/01/11 08:33am Link  |  Print  |  Notify Moderator
Good advice; the dicor comes off much easier when it's warmed up.
I bought a cheap set of plastic scrapers (like putty knives) at Lowes and they worked great. The set had 3 different sizes. You can use a regular putty knife, but round off the corners to prevent tearing the rubber roof. Don't worry about getting all the dicor off; you won't, it's nearly impossible. Get most of it off so the roof is level, clean with acetone, then install your new skylight with Eternabond tape which will last much longer than dicor. Easy job really.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
harold1946
Flagstaff AZ
Posted: 10/01/11 08:36am Link  |  Print  |  Notify Moderator
After removing as much of the old sealent as possible, clean the area with denatured alcohol, the key to a good sealant bond is a very clean surface.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
Golden_HVAC
Fulltime, CA, USA
Posted: 10/01/11 08:47am Link  |  Print  |  Notify Moderator
I agree with the above post to scrape, then clean with acetone, not getting a lot onto the rubber roof, use a cloth towle, and wear gloves too.
Eternabond will make a great seal, no need to replace the caulking every 5-6 years anymore. Yet be careful when applying it, once layed down, it will not move. If you have it in the wrong direction, try to bend it to straighten it out, or cut to make it curve, or cut it off and start over. Once the eternabond glue is set, it will not move for many years.
Eternabond
The only restriction to using Eternabond that I would have is not putting it over any "Fresh" sealant - something that is less than 30 days old. This is because the sealant is outgassing, and chemicals in the sealant might mess with the glue in the eternabond.
Acetone is the recommended cleaner to prep the area for Eternabond use, but it might disolve some types of plastic gloves. I used PVC chemical resistant gloves when applying my bedliner to the roof of my motorhome, and they are rated for use with Acetone or other really harsh chemicals.
Fred.
HuckleberryHunter
Issaquah, WA
Posted: 10/01/11 09:01am Link  |  Print  |  Notify Moderator
Do NOT use any petroleum based product on an EPDM roof. It causes the roof membrane to swell and release from the adhesive that holds it down. Heat and elbow grease is the best method. Clean with light detergent, bleach, or alcohol before applying new. Contact Dicor if in doubt.
I used mineral spirits and learned the hard way. Good luck.
harold1946
Flagstaff AZ
Posted: 10/01/11 09:21am Link  |  Print  |  Notify Moderator
Acetone is a petrolium product and is not recomended for use on EPDM or TPO roofing materials, that includes mineral spirits. Avoid products containing citric acid and any abrasives. The use of any of these will void the warranty.
tvman44
Southwest Louisiana
Posted: 10/01/11 09:53am Link  |  Print  |  Notify Moderator
Heat gun.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
AllegroD
Outdare
Posted: 10/01/11 11:37am Link  |  Print  |  Notify Moderator
I used a metal putty knife with rounded corners, so it would not dig it. More flexible than plastic and won't snap off. Heat makes it easier but is not required.
© 2016 CWI, Inc. © 2016 Good Sam Enterprises, LLC. All Rights Reserved. | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
