wittmeba
Virginia
sailor53 wrote: Ours runs directly into the drain line bypassing the gray tanks. There is a warning label posted in the laundry closet. I wish I saw that when we first used the W/D. The main drain valve was closed and we assumed the water would go into the gray tank that was empty at the time. We were surprised when the water started running out of the washer drain. Fortunately, we were home in the trailer and caught it immediately and there was no damage.
How did you NOT see the message?
They probably do this to avoid filling the holding tank. Also, if it didnt drain (had a separate valve) you could easily overflow the drain if you forgot to open its drain valve.
This does limit its use to when you are with Full Hookups. But I dont think Id want it any other way.
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
Old-Biscuit
Across the USA
Wow........
Washer draining directly into main drain line. Never would have thought it would be plumbed that way.
Mine (NUWA HH II) is plumbed to main grey tank (don't have washer/dryer...just the set-up)
Plumbed to main drain line.....sure adds a new meaning to 'self contained'
christopherglenn
a little over an hour from Yosemite
Question, If it is plumbed into the drain line, won't you get sewer gasses coming back up into the drain if you don't use it (to keep the trap full of water)?
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
joendeb92
Central Ohio
Our washer also has a warning label that states that we must be connected to a sewer with the gray valve open to operate the washer. I can't say where it goes we have not used it,yet.
Roadpilot
NH Seacoast
We had a Diplomat and an Essex with the washer plumbed into the grey tank. Our Prevost does go into the grey.
2006 Millennium Prevost
2013 Chevy Avalanche LTZ Black Diamond
2009 HD Electra Glide CVO Screaming Eagle - mine
2009 Yamaha VStar950 - DW
Cruiser Caddie motorcycle lift
Allworth
Orlando, FL
My Titanium goes into the grey.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
waroland
Mt. Juliet, TN
Our Brookstone is plumbed to the main grey tank.
2002 Fleetwood Revolution
2006 Honda CR-V toad
motorcycle jack
FT all over
All "high end" DRV's go into the grey tank. I'm glad Bluefreight isn't a designer . Yea, your washer is open to the sewer directly, hope your clothes don't come out smelling a little funny.
John
"Motorcycle Jack"
Life time Good Sam Member
Blog: My RV
5th Wheel Blog
Full timing isn't "always camping". It's a different life style living in an RV.
lawaco12
gallatin tn
thanks everyone i put the water to it and it goes to the grey tank but it had a bad odor when i took the plug out should grey have a bad odor
RK Hauler
SW MI
Had the same "doesn't go into the tank" sticker by our W/D hookups. Well is does go into the grey tank. WARNING - don't forget to open the valves! We have a 45 gallon grey tank, forgot to open the valve, and next thing we knew water all over the place under the 5er. Blew out the top of the tank! Glad it was at the top as we were only 10 days into a 10 week trip to AK.
When we got back, used a plastic welder to fix the tank. Worked pretty good, but it still weeps a bit at the seam, so have a new tank on order.
Another note - when working on the tank and testing the fix, I was amazed at how the thing blew up like a balloon when full, especially with a head of water on it like when it backs up into the tub. After seeing that, we will be careful not to let tanks get overfilled. It puts a whole lot of stress on them.
Greg & Roxane
2010 Mountaineer 347THT Toyhauler
2002 F250 7.3 SRW CC LB Tow and Camper Package
2002 Harley Road King
