whjco
Lexington, KY
Greetings folks,
We're camped in Indiana Dunes SP tonight and I can't get any TV reception. I've tried it with the booster turned on and off (the indicator light is working), checked all the connections to the TVs but get absolutely no signal. I don't have a ladder to climb up and check the lead on the antenna but I'm wondering if those can come loose due to wind turbulence? I've not had it in any trees that could have pulled it loose.
Thanks!
Bill J.
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2000 Excursion Ltd. 7.3 PSD
2000 Ford E350 7.3 PSD
RRUGG
Newaygo, MI,USA
We have a worthless antenna on our Kodiak. It stands about a foot high, can't be aimed and it's a flat thing maybe a foot across. Last winter in Yuma we got ABC and a couple of Spanish language stations. Friends with a regular antenna several miles farther away got 10-11 stations. Maybe you have a bad connection and maybe you have a lousy worthless antenna. I guess ours is supposed to be the latest thing and the booster was on.
RRUGG
2009 Chevrolet Silverado LTZ 1500 4x4 5.3L
2011 Kodiak 281RLGS travel trailer
2011 Egg Camper
2010 Chrysler Town & Country
Good Sam life members
Bob & Grace professional retirees
Camped in 49 states. Missing Hawaii.
Rockwood27
Effingham, NH
Do you have a digital or analog TV. The old analog TVs (tube type) no longer receive signals.
Fran
Fran, Mary & Zoey (silver Cocker)
2006 Itasca Sunrise 35A, 2005 W-22, Allison 1000 5 speed
whjco
Lexington, KY
Rockwood27 wrote: Do you have a digital or analog TV. The old analog TVs (tube type) no longer receive signals.
Fran
Thanks for your suggestion, however, both TVs are digital and I also have the extra element on the antenna that's supposed to help digital TV reception. The system has worked fine in the past but for some reason we can't get any signal whatsoever. We were in this campground last year with the same trailer and TVs and didn't have any problems.
dupreet
High Point, NC
If you have the digital mod, the system worked before, and you checked everything short of the rooftop...I would bet your problem lies there!
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
full-timer
Where we park it, USA
Check your tv menu and make sure it is set to antenna and not cable.
Joe
An Indian and a Gypsy
Joe and Nancy
2002 34 foot Georgetown double slide Ford V-10
towing 2004 Chevrolet Cavalier 4 Down
Old-Biscuit
Across the USA
Well you probably aren't getting any channels because you are to far from any stations/transponders.
Check out THIS WEBSITE.
It's a website we use as we travel that shows which stations are available and which direction to point antenna.
None are showing for Indiana Dunes SP.
whjco
Lexington, KY
Found it! I checked out the antenna and it was fine. I dropped the booster down from the ceiling and one of the f-connectors had pulled loose from the cable and the coax from the antenna had come loose from the booster. The f-connector had hardly been crimped so I put it back on the cable, crimped it so it can't come off and now both TVs are working great.
Thanks for all the responses.
pa traveler
usa
I have one of those ,antennas that look like star trek enterprize,so far its worthless.Next door camper gets 9 stations,im getting 2 scrambled stations.I am going to dealer to see whats up with this,I am going to change it to a winegard I think. I have a 2011 lance camper,why would they outfit it with such junk?
Jim Cindy
Northcentral, PA
Were you on cable last time out? Have you switched TVs back to off air reception instead of cable?
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
