RV.Net Open Roads Forum: Fifth-Wheels: Black tank valve stuck part way open
 > Black tank valve stuck part way open
blkdodge
Arizona
Posted: 10/04/11 01:01pm Link  |  Print  |  Notify Moderator
I have a 2010 Keystone Outback 282FE and the black tank valve wont close all the way causing black water to seep in the main dump line. Any thoughts on how to correct this? I have a enclosed underbelly and really dont want to cut a hole in it but I'm afraid I'm going to have to. It has always worked fine until now when I tried to drain some gray water and discovered it wasnt all gray water. staying in a National Park in AZ at this time and dont want to make a mess on the ground. Any insight would be greatly appreciated. [emoticon]
Thanks
David
2012 Dodge 3500 DRW/2012 Heartland Landmark San Antonio.
Chuck&Gail
In the Colorado Mountains
Posted: 10/04/11 01:11pm Link  |  Print  |  Notify Moderator
One thing you might try. Buy a can of silicon spray. Empty tank and take off sewer hose. Spray a bit on shaft, and then spray half a can up the waste pipe while operating valve slowly open and closed. It has worked for me for years when valves get hard to move, so it might fix yours. Certainly worth trying.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
skipnchar
Topeka or somewhere else
Posted: 10/04/11 01:45pm Link  |  Print  |  Notify Moderator
Most likely cause is some TP or other debris jammed in the groove where the gate valve slides. When you can get TO this area it's a very easy fix to usa a length of wire to clean out the groove. If you can't get to the groove to clean it it may be necessary to remove the belly pan.
dbbls
Arkansas
Posted: 10/04/11 01:54pm Link  |  Print  |  Notify Moderator
I see no way of fixing this without cutting into the underbelly. You are going to have to remove the valve and clean out the groove. Another alternative is to get a valve that attaches to the drain outlet. This will allow you to remove the cap and attach the hose without anything draining out. These are available at most RV dealers for about $25.00.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
blkdodge
Arizona
Posted: 10/04/11 02:02pm Link  |  Print  |  Notify Moderator
Thanks for all the responses. As soon as I remove the cap outside I have ( well you know what I mean ) flowing. I just hope when I go to the dump station and use my built in flushing system it will clear. BOY AM i EVER GOING TO HAVE TO BE FAST HOOKING UP THE HOSE.[emoticon] I just hate this part BUT I guess it's all part of the adventure.
Thanks again
David
BillJ999
Home
Posted: 10/04/11 02:13pm Link  |  Print  |  Notify Moderator
As a preventive measure, after I have dumped, and with the black valve still open, I always flush the toilet a few times to make sure nothing is in front of the valve blade before I close it.
Here is one thing you could try:
- Fill the grey tank with hot water.
- Pull out the sewer hose but put the cap on the end so water can't get out.
- Open the grey valve to fill the hose with the hot water.
- Close the grey valve and open the black valve all the way.
- Lift the hose in the air to force the hot water back into the black tank.
- If you can, let it stand for a few minutes, then try to drain it.
This will obviously have to be done at a dump station because when you remove the cap and lower the hose, it will start to drain out. You can just remove the small cap so it drains slowly.
Good luck ...
dupreet
High Point, NC
Posted: 10/04/11 03:32pm Link  |  Print  |  Notify Moderator
Hi,
Once you get dumped, look at the valve - most of these are held together with four screws...not too hard to loosen things up to clear what's jamming things up.
Another "solution" is a twist-on gate valve -
They simply lock on instead of your hose and give you a valve in front of the waste. They are around $20.00
Link
Todd
Todd
1993 Ford E-350 pushed by a 1988 Wilderness 24' TT
jerry1946
alabama
Posted: 10/04/11 03:39pm Link  |  Print  |  Notify Moderator
I had the same problem the last time we camped, something was stuck in the valve it came out the next dumping , works fine now.
remoandiris
Posted: 10/04/11 04:01pm Link  |  Print  |  Notify Moderator
Before I'd cut the underbelly, I'd find out which one of these would fit, then buy it, use it and not worry about it.
http://www.amazon.com/s/ref=nb_sb_ss_i_6_8?url=search-alias%3Daps&field-keywords=valterra+waste+valve&sprefix=valterra&x=0&y=0
Works for me, but my leak was more of a seep.
2011 GMC 3500 Dually
New to me 2006 Jayco Designer 38RDQS
2 Boxers and a Maine Coon
sk734
AL
Posted: 10/04/11 04:10pm Link  |  Print  |  Notify Moderator
I would also put the extra valve on and forget it. It is probably a good idea to have one even as a back up because **** happens!
