sljkansas
Miami Co. Kansas
Has anybody done this, and how well did it work?
I found a Recipe similar to KFC original. My grandmother had another one she came up with that was real close. Since we don't have a pressure cooker and have 4 D.O.s I want to try it. I done a lot of D.O. cooking but never with boiling oil.
Steve & Linda
Son married (1 DIL, 3 granddaughters 1 grandson)
Daughter can now be called a Teacher.
Miami Co. Kansas
2004 F350 CC dually 8ft bed 6.0 PSD
2009 Bighorn 3670RL
B&W under bed hitch with 18k companion hitch
mistressofdistress
Obion, TN
Many things have been fried in iron skillets so why not a Dutch Oven? I don't see a problem.
Proud owner of 2 Barth motorhomes and a Barth Trailer.
rv2go
Fulltime (Knoxville, TN).... or someplace else
You will be able to "fry" the chicken, but it will not be the same as cooking in a pressure cooker. I am sure it will be good though.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
Old-Biscuit
Across the USA
How are you planning on building pressure in a dutch oven and just what are your plans on controlling that pressure???
Messing around with boiling oil under pressure is not something to be done by jury-rigging a dutch oven. Just 5# of pressure can result in death.
I may sound dramatic but 30 yrs. of experience operating/maintaining boilers I have seen the end results from lack of knowledge/dynamics/physics involved.
Please, from a retired boiler operator.....just 'fry' the dang chicken OR go and buy a honest to goodness pressure cooker and then fully understand how to use it.
grinder
Courtenay, British Columbia
IMHO, don't try it. I remember heating oil in a pot with a lid on about 55 years ago just after we got married. I can still smell the burning oil and see the poor pet budgie bird trying to fly under the black smoke. He ended up walking on the floor!!! And I ended up washing walls for a month.
brirene
midwest
Yeah, have to agree. You can't use it as a "pressure cooker". Those have lids that lock down to allow the pressure to build. DO lid will lift...be careful, as previous posters have advised. Or get the right equipment for the job.
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
Big Katuna
Deland, FL
You can use a DO as a fryer, but you can't make it a pressure cooker. A pressure cooker has an air tight seal that raises the pressure inside the cooking area that mimics cooking in outerspace.
My Kharma ran over my Dogma.
lasttruck
Spokane, Wa
If your DO has a well fitting lid, there will be some pressure build up. Not enough to be dangerous, but enough to shorten cooking time.
07 F150
10 Chalet XL1935
Little Kopit
TheMaritimes.ca
No, not the same type of cooking at all.
Dutch ovens are for slow cooking for more interesting texture and enriched flavours.
Pressure cookers are for either faster cooking because of the pressure or for increased shelf life through more than ground level air pressure - ie. low acid foods in 'canning' containers.
Or the two processes are opposites.
& I, I took the road less travelled by.
My Photo Album, featuring Labrador 2006
JudoJeff
Southwick, MA
If you use your dutch oven to fry, and try to use the cover, be careful removing the lid. Steam and/or hot oil can escape as you lift the cover, causing you to get a nasty burn.
I fry donuts, etc all the time in a DO, learned the hard way not to put the cover on.
Take care.
K1BE Jeff
Vulneratus Non Victus
"Wounded but not Conquered!"
