RV.Net Open Roads Forum: Class A Motorhomes: 2000 Bounder F53 Cruise Not Working
 > 2000 Bounder F53 Cruise Not Working
jaycocamper62301
Illinois
Posted: 10/06/11 08:16am Link  |  Print  |  Notify Moderator
Just bought a 2000 Bounder with the Ford F53 chassis V10 and everything works like a dream except the cruise. It has had the cruise update done to it because I found the dealer paperwork saying it's done. Does anyone know where to start looking for this fix? I checked all fuses. No lights on dash, brake lights all work, just no cruise. Help please...have a long trip to Green Bay planned soon!!!!
2015 Cedar Creek 38CK Custom Ordered Black Friday
2011 F450 White Tri Coat, Chrome Package, FX4, Lariat
Yankee Clipper
Cairo, GA
Posted: 10/06/11 09:55am Link  |  Print  |  Notify Moderator
It may be the switch on the steering wheel. Mine won't work when (1) the brights are on or (2) the left blinker is activated.
PITA, but not worth the cash to fix.
BTW, when you say "dealer paperwork", did you mean the recall for the cruise control wiring?
Yankee Clipper
1997 Coachmen Catalina 330MB on F53/Ford 460efi
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS, overgrown Boxer puppy mascot/lousy watch dog
Not overly concerned about depreciation with this rig...
xctraveler
On the road
Posted: 10/06/11 12:01pm Link  |  Print  |  Notify Moderator
Although my first coach was on WorkHorse with Chevy engine I had a similar problem. It turned out that there was a leak in the brake light circuit such that it was always energized in the milliamp range which did not light any lights, but locked out the cruise control which is deactivated by energizing the brake lights circuit!
Paul
2012 Phaeton 36QSH on Freightliner Chassis with a Cummins 380 pushing it. 2011 Cherry Red Jeep Wrangler Rubicon with US Gear Unified Tow Brake System. Check out my blog
FMCA 352081 SKP# 99526
Bumpyroad
Virginia
Posted: 10/06/11 12:55pm Link  |  Print  |  Notify Moderator
happened to mine and it was the VSS or some such, speed sensor on the tranny??
part cost about $8.00.
bumpy
infogeek
Hartford, CT
Posted: 10/06/11 01:24pm Link  |  Print  |  Notify Moderator
I went to have the recall done way back when but they were out of parts at the time so they disconnected the cruise to prevent the hot wires. I never use cruise anyway so I never went back and had it fixed. My paperwork says something about the cruise being 'fixed' too. So maybe something similar happened?
Jon
rk911
Wheaton IL
Posted: 10/06/11 01:37pm Link  |  Print  |  Notify Moderator
when the cruise on our 2000 itasca suncruiser...same chassis as you have...went out a couple of years ago i found that the vaccum hose had slipped off the nipple of the tank. under the hood and off to the right. took all of 30-seconds to re-fasten.
good luck.
'73,
rich, n9dko
Every retired man needs three things....a good truck, a good dog and a working wife
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
Jim@HiTek
Gresham, OR, USA
Posted: 10/06/11 02:39pm Link  |  Print  |  Notify Moderator
Mine and many others are run by a small vacuum pump motor with air reservoir. They sometimes need servicing. New brushes and the like.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
pkunk
Questa, NM
Posted: 10/06/11 07:42pm Link  |  Print  |  Notify Moderator
The F53 cruise recall is a fusible link attached between the original wiring and the master brake reservoir. It may be disconnected or blown. Look under the hood on the drivers side.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
jaycocamper62301
Illinois
Posted: 10/06/11 07:52pm Link  |  Print  |  Notify Moderator
Wow thanks guys....Will start looking tonight!!!!
jaycocamper62301
Illinois
Posted: 10/06/11 07:54pm Link  |  Print  |  Notify Moderator
Ok guys...why does the brake "BUZZ" when you touch the pedal when the engine is off? There's a buzzing noise coming from the steering column
