RV.Net Open Roads Forum: Class A Motorhomes: 2000 Bounder F53 Cruise Not Working
 > 2000 Bounder F53 Cruise Not Working
Bumpyroad
Virginia
Posted: 10/07/11 04:32am Link  |  Print  |  Notify Moderator
jaycocamper62301 wrote:
Ok guys...why does the brake "BUZZ" when you touch the pedal when the engine is off? There's a buzzing noise coming from the steering column
that sound notifies the black helicopters circling overhead as to your final GPS position.
bumpy
bsinmich
Holland, MI
Posted: 10/07/11 10:03am Link  |  Print  |  Notify Moderator
Usually it is a sign that the power steering pump also is the power brake pump and there is nothing pumping when the motor is not running. There is an electric motor that will provide power for the power brakes when the motor is not running.
On my '89 E350 I would blow the fuse whenever I hit the horn with the cruise on. The official Ford fix was to install a larger fuse. The fuse was labeled horn. Check that when you are lookiing for fuses.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
cdking1
el paso, texas usa
Posted: 10/07/11 01:53pm Link  |  Print  |  Notify Moderator
there is an electric brake that is activated when the engine is not running. if you open the hood you will see a lage elecrical looking device attached to the brakes. mine is more of a whine than a buzz. charlie in texas
1999 Southwind ford V10
Gibson hedders and exhaust
Tacoma, 4x4 toad
