RV.Net Open Roads Forum: Tips on how to tell if we will make it on a road?
 > Tips on how to tell if we will make it on a road?
Page of 6
DutchmenSport
Between Anderson, Pendleton, & Lapel, Indiana
Posted: 10/07/11 10:44am Link  |  Print  |  Notify Moderator
hnybdgr wrote:
guess we better not get stuck
Pray it does not rain!
DutchmenSport
2005 Chevy Silverado 3500 Dually Duramax 6.6L V8 Turbo
Century Truck Cap Commercial /Toolboxes
Northeast Outfitters Canoe
2006 Keystone Springdale Model 263DBL
Weight 4985, Carrying Capacity 2575, Hitch 560, Length 30'
Width 8', Height 10' 6"
oneolddog
Vancouver
Posted: 10/07/11 11:03am Link  |  Print  |  Notify Moderator
Sounds like fun but a 4X4 pick-up truck and camper pulling a small trailer is much better suited for that type of camping. I personally wouldn't dream of doing what you are considering.
Adam
2009 Allegro Bus 36QSP (Sold March 2011)
Dream of the day when I can get back RVing.
msmith1199
Central, CA
This may be just me, but I can't imagine driving my 35' motorhome 15 miles on a logging road. You'll be bouncing that thing all over the place and knocking everything loose that can be knocked loose. Not to mention have you looked at a logging truck lately? Most that I see are pretty well beat up.
2004 National Tropi-Cal T-350, Class A, Triple slide, 330 HP Cat DP.
2006 Dodge Dakota 4x4 or
2002 Harley FLSTF Fat Boy on a Trailer or
2004 Polaris Quad on the Trailer
ArchHoagland
Clovis, CA, USA
Posted: 10/07/11 12:01pm Link  |  Print  |  Notify Moderator
Been there, done that.
Once you start on an unknown small road and encounter a problem there is no way to turn around. You best know how to back up with a trailer on your coach. Oh, by the way, have you ever backed up very far with your trailer attached?
Now I never go down a road that is questionable until I know I won't get stuck. That goes for back streets in towns too that have low hanging trees, etc.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
hnybdgr
ca
Posted: 10/07/11 12:18pm Link  |  Print  |  Notify Moderator
Where did you go when you did it? Where did you find it was easy/hard to get to? What states did you do it in?
How big was your set up, and did you ever find a trick to looking on the maps and gauging if you will make it from the maps?
You can get pretty good/accurate views on GOOGLE earth and what not, have you figured out a way to look and know there is no way in hell? We wil have bikes to scout once we are close, but I do not want to drive 300 miles to find out we can't make it if there is a way to gauge it on a map. Thanks for your input.
hnybdgr
ca
Posted: 10/07/11 12:20pm Link  |  Print  |  Notify Moderator
Adam
Sure there are much better set ups for it, but we hate to do things the easy way!
mowermech
Billings, MT
Posted: 10/07/11 12:37pm Link  |  Print  |  Notify Moderator
Keep in mind that logging truck drivers are often driving company trucks, and they don't care if they hit a log or tree sticking out over the road!
Even if they are an owner/operator, getting scraped and dinged by brush is just something that happens, they take it in stride and keep going.
I sure wouldn't be happy if a snag ripped a gash down the side of my old Tioga!
What type of radio will you be using? If it is FRS, you will not have a 15 mile range except under the very best line-of-sight conditions. If it is GMRS (and you have the license), you will still only have that kind of range under the best conditions. If it is a CB walkie-talkie, forget it. If it is a 2 meter FM amateur radio (with the license), at 50 or 75 watts, maybe. If there is a repeater available, no problem.
Good luck.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
StanleyandIris
Louisiana
Posted: 10/07/11 02:20pm Link  |  Print  |  Notify Moderator
The logging roads I have traveled have soft spots - deep sand - and sometimes the distance between one rise and the next is too close for maneuvering our 42'MH. Take note of both scenarios so you do not get stuck in sand or between rises in the road.
Iris
deandec
Northern CA
Posted: 10/07/11 03:05pm Link  |  Print  |  Notify Moderator
I suspect the 45' Travel Supreme has a very low ground clearance compared to a logging truck, or most any tractor/trailer and most motor homes.
Three point turns, tight corners with your wheel base length and high centering would be my concern with your type coach.
Backing up a long distance with a 22' trailer and a very narrow road would seem to be a challenge.
I would think driving to the destination with/out the trailer would be challenging by itself.
Of course if the worst were to happen, you would want to make sure your towing company would provide service in such a remote location or have lots of room for new charges on your credit card.
Dean
95 CC Magna, Jeep GC
slickest1
canada
Posted: 10/07/11 07:13pm Link  |  Print  |  Notify Moderator
I would also worry about popping a windshield from too much twisting.
2000 H.R. Imperial 38wds rr8r roadmaster, isc 350 cummins
2007 Chevy Trailblazer, Blue ox towbar
Ready Brake with breakaway.
Page of 6
