RV.Net Open Roads Forum: Fifth-Wheels: Hot water heater
 > Hot water heater
esfd243
East Syracuse, NY
Posted: 10/10/11 03:25am Link  |  Print  |  Notify Moderator
I have a 2011 Cougar 324RLB. When I hookup to electric I turn on the DSI button to get hot water. I believe this is electric, is that correct? When I left the dealer with the unit last year I thought I had the delivery person leave the heater on electric. I have always heard the tank cycle from the outside light is was lighting up or something. This makes me think that its on propane and not electric. Im a little confused on this!
Mike, Dawn & Mallori
2016 Hemisphere 368RLBH
2012 Chevy 2500 HD D/A 3.73
Executive
Posted: 10/10/11 03:30am Link  |  Print  |  Notify Moderator
When you push the button you should be on electric. There should be a red light that tells you also. Did you get a manual with your coach? If not, your heater is most likely an Atwood. Grab the model number and you can download the manual. ...Dennis
BTW... you can't HEAT HOT water....it's simply a water heater..[emoticon][emoticon]...D
THE WORLD IS CHANGED BY YOUR EXAMPLE, NOT BY YOUR OPINIONS
Dennis and Debi Ninth Year Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Allworth
Orlando, FL
Posted: 10/10/11 01:03pm Link  |  Print  |  Notify Moderator
The great RV fortune teller forsees a burned out WH element in your future.
It appears that the only switch for your electric portion is outside, in the heater enclosure. If you leave it turned on all the time, sooner or later you war going to plug in your shore power line with no water in the tank and it will be goodby element.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
2008Wildcat
PA
Posted: 10/10/11 04:34am Link  |  Print  |  Notify Moderator
DSI means direct spark ignition, or, you aren't using a pilot light to light the propane side of the water heater.
Typically, you have an electric switch on the inside, and one inside the heater cover on the outside.
Also a DSi switch for the propane inside. If you push the switch, and hear it clicking, that is the DSi trying to light the propane. It should then light with a "whoosh".
If it is silent, then you are using electric. It doesn't make noise when on electric.
2013 Columbus 320RS
2011 RAM 3500 Outdoorsman SRW 6.7 Cummins- tweaked!
enblethen
Moses Lake, WA
Posted: 10/10/11 07:04am Link  |  Print  |  Notify Moderator
DSI or Direct Spark ignition uses 12 volts DC to lite the propane fired water heater. There is normally one switch inside the rig, none outside.
An "electric" water heater uses 120 volts AC to heat the water. There is normally a switch inside to turn on plus a safety switch in the outside access.
Best thing to do is get the make and model number of the water heater and post that. The sticker is normally in the outside access.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
mstrack121
Weatherford, TX
Posted: 10/10/11 12:32pm Link  |  Print  |  Notify Moderator
I have the same 324 in a 2010 model. Mine does not have an inside switch for electric. The only switch inside is propane. I have to turn the water heater on and off, from the outside. Pain sometime!
Full Timing 2010 Carriage Cameo 36FWS. Sold the stix and brix.
Working to hunt and fish!
DW-Flying the dream (SWA)
3 wonderful grandkids to take with us!
2008 Silverado LTZ D/A 3500 DRW
2010 Cougar 324RLB
bpounds
Senile, er I mean
Posted: 10/10/11 01:13pm Link  |  Print  |  Notify Moderator
mstrack121 wrote:
I have the same 324 in a 2010 model. Mine does not have an inside switch for electric. The only switch inside is propane. I have to turn the electric water heater on and off, from the outside. Pain sometime!
Correct ^^, except I added a word to clarify what you meant. This is how Cougar is set up with a Suburban WH.
And Allworth is correct too, that there is the potential to burn out the element. I think electric is a poor way to heat water, so my electric switch outside stays pinned in the off position at all times. If I ever do want to use it, I will have to make the effort to turn it on.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
esfd243
East Syracuse, NY
Posted: 10/11/11 04:59pm Link  |  Print  |  Notify Moderator
Understood now. I think I have it. Thank you for all the advise. As usual, I love this website !
greende
Syracuse,NY
Posted: 10/11/11 05:24pm Link  |  Print  |  Notify Moderator
I always use propane. When I had my Gulfstream with the Atwood with the switches inside, I sometimes used electric to maintain temp to save my propane. My last two cougars with the Suburban WH, I have not even used electric.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
USAF 1968 - 1972 Viet Nam '71 - '72
jetcare
Mobile RV Repairman - Mission, TX
Posted: 10/11/11 05:35pm Link  |  Print  |  Notify Moderator
What do you mean you can't heat hot water. If water is hot at 125 degrees F. how do you get it to 212 degrees F.?
2016 F-250 Crewcab 6.2L 4x4
2012 Palomino Sabre 32' Travel Trailer
 > Hot water heater
