RV.Net Open Roads Forum: Tech Issues: No lights on house batteries
 > No lights on house batteries
kennithbk
North Carolina
Posted: 10/12/11 08:22pm Link  |  Print  |  Notify Moderator
I'm sorry folks they are installed like the picture above negative to negative and positive to positive. Any other suggestions? Thanks and sorry for the mis information.
mena661
Posted: 10/12/11 08:35pm Link  |  Print  |  Notify Moderator
Try the fuses as others have suggested.
Trojan L16 6V's 740 Amp-hours
The Falcon
Monterey Co, CA, USA
Posted: 10/12/11 09:44pm Link  |  Print  |  Notify Moderator
Some things may be on a commen ground. Maybe a ground wire came loose someplace. you could try running a ground wire to a light and see if it lights. Probably a fuse somplace though.
Joe
Precision Guesses
Joe&Jan 2003 Hurricane 30Q V10
2004 Jeep Liberty, Blue Ox, Brake Buddy
opnspaces
San Diego Ca
Posted: 10/13/11 12:58am Link  |  Print  |  Notify Moderator
You said all the fuses are good, does that mean that you measure battery voltage at the fuses with the vehicle off and no shore power plugged in? Or did you do a visual inspection.
To measure voltage at the fuses you'll have to find a place to ground the meter. Either pull the front off the panel to find a ground or run a long wire to a frame ground.
If you get battery voltage at the fuses then verify that BOTH sides of teh fuse read the same. you can poke the positive lead of the meter into the small holes in the back of the fuse to do this.
If you want to look for resistance/voltage drop, measure the battery voltage at the batteries and compare it to the measurements you get at the fuses.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
RoyB
King George, VA
Posted: 10/13/11 08:06am Link  |  Print  |  Notify Moderator
Just confirm at the battery terminals that the neg (-) terminal on each 12VDC battery go directly to trailer frame ground. Sometimes the new batteries have the terminal posts in different positons than what you removed so you may be also be reversed as well... Just confirm the negative (-) terminal goes to frame ground on each battery. The case should have a (-) symbol or be marked NEG...
You will have to locate your two fuses on the converter/charger unit marked REVERSE POLIARITY and replace those and there also may be another IN-LINE fuse close to the batteries that may also be blown.. If you indeed series those two batteries and put out 24VDC to the system then hopefully the fuses blown first and didnt damaged anything. This can start adding up pretty quick $$$ wise.
Like they always used to tell me at work "Bend over Braddy" or at least get a NCIS slap on the back of the head...
Sure hope you come out ok on all of this...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
RoyB
King George, VA
Posted: 10/13/11 08:12am Link  |  Print  |  Notify Moderator
After reading the post while I doing my slow typing - you are down to two thing now...Look for the MARKED (-) negative terminal on the battery box and confirm that you havent reversed the battery cables and then look real hard under the trailer for the in-line fuse. You may have to fish the battery cable back under the trailer to find it. If this is a first time install of two batteries you may also have to increase the in-line fuse size. AT least 45AMP I would say. It is probably a 30A with only one battery installed. I have an 100AMP fuse installed on my three GP24 batteries main line feeding the converter/charger.
* This post was edited 10/13/11 08:22am by RoyB *
Wherever I happen to park
Posted: 10/13/11 08:23am Link  |  Print  |  Notify Moderator
Well, since you did not say if they are six volt or 12 volt I can not say "I hope you wired them in ______"
But I will echo the battery cut off switch comment, Also you may have blown your master fuse if you put 'em in wrong.
Pokey2
Bel Marin Keys, CA
Posted: 10/13/11 11:46am Link  |  Print  |  Notify Moderator
You say “no inside lights.” Does other 12-volt stuff work, such as your water pump?
SLOW-1
Central NC
Posted: 10/13/11 12:52pm Link  |  Print  |  Notify Moderator
I had the same problem when I put in new batteries, eventually I found the 30 amp breaker that was tripped. Mine was under the dash, completely away from all the other "house" breakers.
Take time to be nice to someone today.
1999 Winnebago Adventurer 32 (454 Chevy)
Check out our first cross country trip.
