RV.Net Open Roads Forum: Toy Haulers: fuel pump
Search only in Toy Haulers
 > fuel pump
dirtbag3
Hesperia Ca.
Posted: 10/15/11 01:12pm Link  |  Print  |  Notify Moderator
My fuel pump in my Stellar quit working its been chased down to the punp motor. Im looking to find suppliers so I can purchase a new one.
midnightsadie
ohio
Posted: 10/15/11 01:40pm Link  |  Print  |  Notify Moderator
couple on e bay, type in stellar fuel pump
tom cav
orange co
Posted: 10/15/11 03:02pm Link  |  Print  |  Notify Moderator
are you sure its not just the gears swelling issue?
2007.5 cc,sb.ltz 4x4 d/a ,o9 eclipse stellar 34 lksg 2012 xp-4, 08 4seat rhino . yamaha 125 grizzly 125 breeze
dirtbag3
Hesperia Ca.
Posted: 10/15/11 03:13pm Link  |  Print  |  Notify Moderator
I havent gotten that far I just checked for current.
It stopped while I was filling my truck before leaving a couple weekends ago.
Camorhino
Bakersfield, CA
Posted: 10/15/11 04:17pm Link  |  Print  |  Notify Moderator
If you didn't blow a fuse, it probably just needs a new gear set in the pump. Loosen the 4 bolts on the side of the pump housing just enough it doesn't leak and try turning it on. If it spins, your nylon gears in the pump probably swelled while sitting unused. Cheap fix, if I remember mine, it was less than 30$.
ng2951
Louisiana, USA
Posted: 10/15/11 06:28pm Link  |  Print  |  Notify Moderator
I wired mine to run in reverse, then switched it back to normal polarity and it worked fine.
Foard County News & Sassy Schoolmarm
with Lady & Chloe
2012 Unleashed 27SBU
2013 10 days camping
2012 50 days camping
'07 GMC Sierra 2500HD Classic 4x4 LBZ Duramax Diesel
Honda 2000sThe Bayou Bounty Hunters Cowboy Club
The Single Action Shooting Society
Dirtclods
Newport Beach
Posted: 10/17/11 11:26am Link  |  Print  |  Notify Moderator
dirtbag3 wrote:
The wire from the switch to the motor was bad. I just checked all the power through the switchs. Who would think the wire would be bad.
Fixed
I was going to chime in but you already handled it.
My attitude had the same issue.
tom cav
orange co
Posted: 10/15/11 06:38pm Link  |  Print  |  Notify Moderator
last yr mine stoped it was the gears swelling .easy fix no $ just a little time take cover off pull gears ,you want to take approx 004-008 ,lay gears on a flat hard surface /sandpaper. move in a *8 done install .like new
dirtbag3
Hesperia Ca.
Posted: 10/16/11 08:27am Link  |  Print  |  Notify Moderator
ill try pulling the gears today.
It quit while i was using it though so swollen gears a far stretch.
Fuse is good ran a jumper on switch checked for current, now I'll pull gears. If not I just need a motor or complete assembly.
My gas station is used all the time. I ride off my property and fill all the bikes my kids ride on my property. Its been along time since I had to go to the gas station for gas lol
dirtbag3
Hesperia Ca.
Posted: 10/16/11 12:38pm Link  |  Print  |  Notify Moderator
Fixed
 > fuel pump
