RV.Net Open Roads Forum: Tech Issues: What type of battery charger
 > What type of battery charger
Eyeland
On The Road
Posted: 10/16/11 07:54pm Link  |  Print  |  Notify Moderator
I have a Honda 2000I gen and want to get a battery charger to help in charging batterys when boondocking instead of running power through the fifers' converter. I know I need a three stage charger but not sure of the power needed. Any suggestions on make, type or thoughts about this matter...Thanks
09FLSTC
Out West
Posted: 10/16/11 08:25pm Link  |  Print  |  Notify Moderator
Why would you not want to use your trailer's converter/charger? Some of them are very good and you would be wasting money if you already have one. If not, replacing your bad converter with a good converter would make more sense. If that does not do the trick, THEN entertain a secondary charger.
OnaQuest
Old enough to be a
Posted: 10/16/11 09:24pm Link  |  Print  |  Notify Moderator
This is sound advice.
You don't need a multistage charger to use with your generator. The idea when charging with the gen+charger is to charge about as fast as possible, so a manual single stage charger would do nicely.
A good multistage charging CONVERTER would be a good investment as it may be charging for long periods of time when hooked to shore power and that's when you need the multistages to prevent water loss and resultant damage.
Gale Hawkins
Murray, KY
Posted: 10/16/11 09:58pm Link  |  Print  |  Notify Moderator
Some consider this line (under B&D label too) to be apex for RV use.
Some seem to be able to charge their TV through their converters I guess.
Seriously there are many reasons to own a great stand alone battery charger. The Desulf Mode that comes on some of this line of chargers will boost battery life to pay for the charger over time. The Equalize Mode can really help too.
smkettner
Posted: 10/16/11 10:41pm Link  |  Print  |  Notify Moderator
Get 40a but evaluate what your converter is doing before spending money.
675 watts solar
09FLSTC
Out West
Posted: 10/16/11 10:45pm Link  |  Print  |  Notify Moderator
Gale, can you help me with this? What do you mean?
The desulfation mode is a total joke on portable chargers, we all know that. Nobody is charging TV batteries through the converter. It can be done but does not make sense. There is no reason too unless during storage and then a Trik-l-start makes so much more sense.
Gale Hawkins
Murray, KY
Posted: 10/17/11 06:26pm Link  |  Print  |  Notify Moderator
mena661 wrote:
Those that use this mode on the B&D VEC1093DBD have had great success including myself. Works great, no joking.
I had a set of 4 DC-24 batteries on an UPS and run time tests had dropped from one hour to 30 minutes. Did 3 24 hour cycles on each one and got the run time back up to 45 minutes and used they nearly another year using some 1093 class chargers so I know the Desulf Mode works.
mena661
Posted: 10/17/11 12:55pm Link  |  Print  |  Notify Moderator
* This post was edited 10/17/11 01:29pm by mena661 *
Trojan L16 6V's 740 Amp-hours
RoyB
King George, VA
Posted: 10/17/11 06:07am Link  |  Print  |  Notify Moderator
To answer the OPS first question the Black & Decker 40AMP Smart mode charger VEC1093DBD (Amazon.com) is a popular unit for RV use. I have a 2KW Honda EU2000i generator and it will operate the Black & Decker just fine if I want to plug it directly into the generator to charge my battery bank. The 2KW Honda generator also operates my PD9260C on-board "Smart Mode" Converter/Charger to charge my battery bank in 3-4 Hours of generator run time with the Trailer shore power cable directed connected to the 2KW Honda generator using a RV30A-15A adapter plug. I use the RV30A-15A Dual Honda Adapter PLug from Amazon.com which plugs into the the dual 120VAC Honda receptacle (both sides) to give a good connection.
I prefer to use the trailer on-board converter/charger when re-charging as I get the use of my 120VAC receptacle during the generator run time to make my fresh bean coffee or cook up something with the electric skillet while I am re-charging my batteries...
The trick for us is to re-charge our batteries everyday for 3-4 hours when camping off the power grid and we do just about everything we normally do at electric sites except we lose out on air conditioning and use of our high wattage microwave unit.
Works for us great doing it this way.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Gale Hawkins
Murray, KY
Posted: 10/16/11 11:08pm Link  |  Print  |  Notify Moderator
OFFLSTC by just following the Desulf Mode instructions you should see longer run times for your deep cycle batteries if you are experiencing decreasing run times by using that feature on one of these chargers with the feature. Do you own/using one?
There are good reasons to own a good portable three stage charger these days.
