RV.Net Open Roads Forum: Class A Motorhomes: Lost prime?
 > Lost prime?
Triumph GT6
92067
Posted: 10/16/11 08:49pm Link  |  Print  |  Notify Moderator
Changed fuel filter on our '02 Winnebago Journey, CAT 3126B motor. Now, it won't start...
Single filter, no prime pump
Filled new filter with clean fuel
Front of coach higher than rear
Pressurized fuel filler
Cranked 30 seconds numerous times, with appropriate cool times
Suggestions?
2002 Winnebago Journey DL 36
CAT330 Allison 3000
Fleet Man
Western WA
Posted: 10/16/11 08:55pm Link  |  Print  |  Notify Moderator
Last resort but it always works. "Crack" the fuel lines at each injector, crank the engine til fuel squirts at each loose connection, retighten each connection and attempt to start the engine again. That procedure shold bleed out all air in the system up to the injectors.
2007 Winnebago Journey 34H
Toad, '08 Ford Taurus X
Blue OX, Aventa
US Gear UBS
toughnut
usa
Posted: 10/16/11 10:31pm Link  |  Print  |  Notify Moderator
Suggestions?
Not familiar with cat but what do U mean by pressurized the filter?
How do U do that?
How much fuel drained out of the filter housing when U removed fuel filter.If any at all its now got air in the injector lines.If U do a search on here you will see a fellow ended up with same problem U have,same year and motor,He bought the primer pump and bolted it on,pumped her up and it started right away.
toughnut
usa
Posted: 10/16/11 10:39pm Link  |  Print  |  Notify Moderator
Suggestions?
GO to this post(have to copy and paste)
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25398505/gotomsg/25404338.cfm#25404338
farmer_boots
Weirsdale, Fl
Posted: 10/17/11 02:44am Link  |  Print  |  Notify Moderator
I use to have this problem with a truck I had. Every time I changed the fuel filter I would get air in the system. The fix was to bleed the air out at the input to the injector pump. If that does not work then you have to do each injector.
2006 Monaco Diplomat
Gonnacall
NV
Posted: 10/17/11 04:52am Link  |  Print  |  Notify Moderator
Check to see if you have a primer pump (should be near the engine fuel filter. If you do, loosen the handle and pump it up until you have pressure on the pump handle. Tighten it back up and then try to start again, once it starts raise the throttle to around 1500 rpm for 30 seconds to make sure all of the air is out of the lines.
2001 Journey DL - Cat 330
2003 Trailblazer
Triumph GT6
92067
Posted: 10/17/11 07:38pm Link  |  Print  |  Notify Moderator
I'm no diesel expert, but it looks more like a 'throttle body" type injection. Doesn't appear to have' individual injectors... As previously mentioned, there is no primer pump on this coach, it has a single remote mounted filter.
toughnut
usa
Posted: 10/17/11 07:54pm Link  |  Print  |  Notify Moderator
Did you do what i suggested ?
Look at this post?
Livin Good
On The Road
Posted: 10/17/11 07:56pm Link  |  Print  |  Notify Moderator
You've got to be kidding....Cat has NEVER has a "throttle body injection system"....go to a professional and have him prime and start your engine...
Telemarc
B.C. Canada
Posted: 10/17/11 07:59pm Link  |  Print  |  Notify Moderator
If you can install shutoff valves on both lines at the fuel filter . Close both valves, install new filter full of fuel , open valves and away you go.
Sold the house, time to see the world.
 > Lost prime?
