mac_camper
Illinois
We have been considering replacing our sink faucet which has two handles with the single handle version. I see there is one in Camping World's catalog. Anyone done this and have suggested models?
jbbrick
Near San Francisco
Just go to Home Depot or Lowe's and get a good Delta or Moen, it just takes a standard kitchen faucet, nothing special.
'02 Winnie Adventurer 32V
2010 Ford Escape toad
mike4947
N. Syracuse, NY
Well not really a kitchen faucet. The vast majority of popup faucets use a 4 inch center to center distance for the down piping. Check before you purchase and save a trip back to the store.
Another thing we've encountered is with fold over sink cabinets is the height of the faucet. Check with the sink flipped on how high the facuet can be.
And most faucets sold as replacements in RV centers are like the original...all Plastic. Figure just a few years before it goes bad.
blog.rv.net Your daily guide to the Open Road
Subscribe to the daily digest
They say you learn by your mistakes, in that case I must be a genius.
LAdams
Northern Illinois
Excellent idea of going to a big box store like Home Depot, Menard's, Lowe's, etc., and getting a "regular" household type faucet... You'll more than likely get a lot more faucet for a lot less money and for sure you'll get a higher quality faucet than the RV junk regardless of money spent!!
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
AlamsoaBorn
Colorado
I tried to purchase on at a big box store. Couldn't do it. My pup faucet is on 4" centers, the kitchen faucet is bigger. Best I could do is use a bathroom sink faucet and then it didn't have a spout that would work in my sink. It would have been nice, but...
fairfaxjim
Fairfax, CA
I replaced the sink faucet in my Starcraft. It was getting ugly and also had a small spout that hardly anything would fit under. I found one that mounts exactly the same with a longer/taller spout on E-bay. Had plenty of room for the larger fixture when the sink was flipped over.
Jim & JoAnne
2007 Toyota Tundra Double Cab
2004 Starcraft 11RT (Replaced by)
2011 Eclipse Milan 18CK Travel Trailer
Aslag
Washington State
I replaced mine with a Moen laundry faucet from Lowes. It's a big improvement over the cheap stock plastic faucet. I have a swing down type galley and the new faucet spout must be removed to clear the bunk when it's slid in. The spout unscrews easily by hand and is a small price to pay for the added convenience of the increase in spout to sink clearance and the ability to swivel.
2001 Chev Silverado 1500 Z71
2007 Flagstaff 228D
Trailer Mods
crasster
Dallas
You may be able to find a cheap one on ebay.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
nfisherman
IL
I'll add to the chorus that says check the big box stores. I replaced my cheap plastic RV faucet with a brass one from Home Depot. I bought the store brand (Glacier Bay) and it works fine. My faucet was on 8-inch centers. If yours is on 4-inch centers, you can still probably find a bar faucet that would work well for you. You'll save money and it will be a better faucet than you can probably get from and RV parts store. You won't know until you look.
aftermath
Washington State
This will be a great improvement. My problem was finding a faucet that was short enough to fit under the bunks as they slid in when we folded things down. 4 inch centers is the usual but then you need to carefully look at width, height and how far away the spout dumps the water. In my Starcraft HTT, the water barely cleared the counter top.
I changed out all of my faucets in all of my trailers to single handle faucets. When boondocking, they save a lot of water. With two you have to regulate the water temperature each time, using both hands. With the single handle, one hand quickly turns the water on and off without all of the fiddling around to get the correct temperature. The water saved by shaving alone can justify the new faucets.
2008 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Prodigy Controler
