RV.Net Open Roads Forum: Travel Trailers: Plumbing question?
 > Plumbing question?
Dirtfan
SE MN
Posted: 10/17/11 08:04pm Link  |  Print  |  Notify Moderator
I winterized my hilo tonight and was wondering what these valves are for
Chinook
Missouri
Posted: 10/17/11 08:11pm Link  |  Print  |  Notify Moderator
They appear to be low point drains used to dump water out of the hot and cold waterlines.
Dirtfan
SE MN
Posted: 10/17/11 08:42pm Link  |  Print  |  Notify Moderator
Thanks for your help Chinook
brirene
midwest
Posted: 10/17/11 08:52pm Link  |  Print  |  Notify Moderator
I would agree with Chinook, especially if the tubing goes directly down from those valves. Can't tell from the pict.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
LAdams
Northern Illinois
Posted: 10/17/11 10:28pm Link  |  Print  |  Notify Moderator
Yep - low point drains...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
mobeewan
Hampton, Va
Posted: 10/18/11 03:32am Link  |  Print  |  Notify Moderator
Looks like the pull up to open low point drains that were in my old trailer.
Av8orlouTX
Posted: 10/18/11 12:14pm Link  |  Print  |  Notify Moderator
hilotrailerforum.com
You can go to this forum to find out all you want to know about a hilo.
2015 GMC Denali HD Z-71 4x4 Duramax
2004.5 Chevy 2500 CC SWB Duramax (lly)
2013 Cedar Creek 34rlsa
2003 Four Winns Funship 214
Dirtfan
SE MN
Posted: 10/18/11 07:52pm Link  |  Print  |  Notify Moderator
I've been known to hang out there [emoticon] Hi-LO Forum
Av8orlouTX
Posted: 10/19/11 08:19pm Link  |  Print  |  Notify Moderator
My HI-Lo doesn't have those valves like in your photo.
BigPackFan
Endicott, NY USA
Posted: 10/20/11 06:55pm Link  |  Print  |  Notify Moderator
My guess would be low point drains also.
For what it's worth, the drains on my TowLite were under the "sofa", no where near the furnace or water pump.
BPF
Searching for the right RV
2007 GMC Envoy
