RV.Net Open Roads Forum: Fifth-Wheels: B&W companion hitch theft protection
 > B&W companion hitch theft protection
jamway
Ranger TX.
Posted: 10/18/11 04:09pm Link  |  Print  |  Notify Moderator
If a guy is going to get in your pickup bed and loosen four nuts and one bolt to get your hitch I don't think one or two locks will stop him.
Happy Camping
2004 2500 CTD HO LB 4X4 auto
2005 Discover America 29 RL
James
bluck
Silver City, NM 88061 USA
Posted: 10/18/11 04:32pm Link  |  Print  |  Notify Moderator
I just drilled a 1/4 inch hole in one of the base pins and then pad lock it. If they want it bad enough they will get it. I also drilled the latch handle and put a hitch pin in it so I can remove it. I really dont think it's much of an issue though.
2004 Chevy.
Duramax-Allison
2004 Thor Mirage
Kawasaki Prarie 700
JDMopar
Asheville,NC
Posted: 10/18/11 05:59pm Link  |  Print  |  Notify Moderator
When I unhook at the campground, I just take the head off and put it in the basement. I lock the base to the tie down loops, but that would just stop the lazy thieves.
fj12ryder
Platte City, MO
Posted: 10/18/11 06:01pm Link  |  Print  |  Notify Moderator
IMO if someone is ambitious enough to steal a heavy, awkward, not exactly easy to pawn item, then I don't think a couple of padlocks are going to slow them down in the slightest. Doesn't really seem like a spur-of-the-moment theft. There are battery powered abrasive wheel cutters that will go through a padlock like a knife through butter.
I just can't work up any real concern.
Howard and Peggy
"Don't Panic"
srink
Indianapolis
Posted: 10/19/11 09:47am Link  |  Print  |  Notify Moderator
I have a valley removable hitch. pull 4 pins and it's out.
I drilled the hole in one of the pins a little larger and put a small lock on it. Sure they can cut the lock but it's a deterent. you can also buy hitch pins with locks.
Condo on Wheels
tdeal823
N.W. Ohio
Posted: 10/19/11 10:26am Link  |  Print  |  Notify Moderator
wheatfarmer wrote:
Does anyone have a way to protect the companion hitch from getting stolen out of the back of your pickup? Heard of a few getting stolen and was looking for a way to secure mine. Looks like you could just loosen the top bolt on the square post pull the pin and lift the whole thing out and be on your way with it. What has anyone done to keep their's from being stolen?
I have an NRA sticker on my truck.
2008 Silverado 2500HD DMax LTZ cc sb 4x4 EFILive tuned, Blocked, Deleted, Rerouted and removed B&W Turnover ball and 5th Companion
02 F250 4x4 Auto Ex LWB SRW 7.3L B&W, RideRite, 5"exhaust. TW6 chip. 195k
2011 Sabre 32BHOK-6
