jerryent
salina ks
I keep my 2004 holiday rambler scepter plugged in to 30 amp in our morton building and noticed the power was off and 30 amp breaker was off. I flip switch and breaker went off again. tried a 15 amp same thing then started genset it started but when it went to put power on it stopped. Any ideas? tried turning all MH breakers off but no help.
jerry
2004 HR Sceptor, 2001 saturn l-300 toad, brake buddy
wolfe10
If it blows the shore power breaker when the coach main breaker is off, that would suggest a short in adapter, shore power cord, ATS or going into the coach main breaker box.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
Dale.Traveling
Newport News, VA
I would start with the power transfer box. Almost sounds like both the shore power and generator relays are closed at the sametime. With the breaks all tripped the next item is the transfer switch.
Keep us informed on what you find.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
jerryent
salina ks
Thanks I will check it out.
crah
Las Vegas
Have you done anything recently like run the gen while plugged in? The transfer switch on mine gave me recent problem although not the.dame as your problems. A good tap on the transfer swith may make it work temporarily. There is a small circuit board inside the switch that has a tiny button. Turn it in the on position and see if it does anything.
2003 Holiday Rambler Scepter 36PST 3 Slide
Cummins ISC 350/Side Radiator
Banks System
2011 Buick Enclave Towed
Ready Brute/Ready Brake/Blue Ox
jerryent
salina ks
Thanks will try it. Is that the black box in the bay that powercord enters?
siggyd777
Northern Illinois
Yes, the ATS ,Auto Transfer Switch is where the powercord comes in.
Happy Trails
Siggy & Ursula
2011 Dutch Star 4020,ISL 400,Compr.brake,FTL XCR,IFS
Allison MH3000
2005 Saturn VUE AWD V6 , Brake Buddy,Roadmaster Sterling,
Camping since 1975 Pop-Up,1986 22Ft.TT,1999 Gas MH,2005 KSDP,
2011 DSDP,FMCA 368283 , NKK 17385
crah
Las Vegas
That would be it. Mine is an iota and looks like I will need to replace mine someday soon.
jerryent
salina ks
Thanks, I will check it out. Got to get the power on as it will be 25 tomorrow
EckE
Lyons, KS
Was wondering what was the solution to the problem.
2005 Holiday Rambler 36WDD Vacationer
