RV.Net Open Roads Forum: Tech Issues: Fridge won't stay lit on gas
 > Fridge won't stay lit on gas
k9doctor2b
Vista, CA
Posted: 10/20/11 07:10pm Link  |  Print  |  Notify Moderator
I have a Norcold fridge. I am on battery power with a full charge.
When I turn the fridge on, I can hear it clicking but F keeps coming up. I can see a pilot light burning, but it just keeps clicking, then shuts down (flame goes out) and the F comes back.
Any ideas?
Ryan
hmknightnc
Wilmington, NC
Posted: 10/20/11 07:40pm Link  |  Print  |  Notify Moderator
Flame sensor (thermocuople) not positioned correctly or not working. There should be a wire in the flame. This senses if a flame is actually burning based on heat. If it doesn't sense a flame the control board will time out and shut off propane as a safety measure
k9doctor2b
Vista, CA
Posted: 10/20/11 07:42pm Link  |  Print  |  Notify Moderator
That would make sense. I wish I had checked this before dark! I will see tomorrow morning, but this would be likely.
1Sammiedog
Posted: 10/20/11 09:52pm Link  |  Print  |  Notify Moderator
The flame ignitor is also the flame sensor. Once the flame has been ignited the probe sends a signal back to the board that the flame is burning.If no signal is received the propane then shuts down to the burner. They're fairly cheap to replace. About $20 or so.
1Sammiedog
stein4
California
Posted: 10/20/11 11:34pm Link  |  Print  |  Notify Moderator
Mine does the same thing; I turn the gas off after a trip and when I turn it back on I get the error for a few cycles. I have to turn it off and back on about 10 times. After that if works great. Maybe it gets air in the line?
Gale Hawkins
Murray, KY
Posted: 10/20/11 10:36pm Link  |  Print  |  Notify Moderator
If we have had our Norcold 6162 off for a long time sometimes it will error out 15-20 times back to back then keep burning. So far after enough times it keeps working and works without fail there after until shut down for a long time.
4*phun*2
Canada
Posted: 10/21/11 05:32am Link  |  Print  |  Notify Moderator
The flame sensor can usually be clean with a rough scouring pad.
Glenn & Karen
'08 Chevy LT 3500 HD 4x4 CC LB DRW (nice hips)
'06 F350 4X4 Lariat CC LB DRW (nice hips) retired
'09 Victory Lane 38SRV Toy Hauler
'02 HD Road King FLHRCI KRUZN
'04 F150 XLT Super Crew
Our Toys
John&Betty
Alberta
Posted: 10/21/11 05:45am Link  |  Print  |  Notify Moderator
I turn off the gas as well after a trip. When I first had my trailer the same thing happened to me and the fridge would try to start and wouldn't. Then I remembered someone had told me when the gas has been turned off between trips, light one of the burners on the stove and that will ensure that there is a steady supply of propane in the line. Since I've done that, my fridge ignites on it's first try.
John & Betty
2007 Dodge Ram 1500
2010 Keystone Bullet 246RBS
k9doctor2b
Vista, CA
Posted: 10/21/11 08:20am Link  |  Print  |  Notify Moderator
There is definitely good gas flow with a nice blue flame.
There is an electrode in the flame which is lighting it just fine, but it must not be sensing the heat. I guess it needs to be replaced.
k9doctor2b
Vista, CA
Posted: 10/21/11 03:48pm Link  |  Print  |  Notify Moderator
Its not the electrode. I am going to have to swap the board I guess.
